Replaced Brakes On All Four Now The Front Are Locking Up?
Hi everyone ~
I know this is the place to come, when you need answers!
I have a 99 Mustang GT 4.6L Convertible. Recently, I have noticed that my front brake calipers aren't releasing like they're supposed to, especially when they get warm. When you jack the car up(Brakes warm to hot) I can only get about 1 revolution out of each side. I have heard several possibilities, but I want to hear from fellow Mustang lovers. Pins sliders all move freely Claiplers move freely everything is clean piston go back freely as well i'm lost
1999 Mustang GT Convertible :SN:
loosen the bleed valve a bit and see if fluid is under high pressure. do not let any air in or let too much oil come out of it . after you let some fluid loose check for tight brake, start the car and pump the brakes a few times then see if the caiplers are still under pressure
