Recommended diagnostic steps
After the car sits with engine off, crack a bleeder screw at one locked caliper.
- If fluid squirts under pressure and the wheel frees up → restriction is upstream (hose or master).
- If no change → caliper piston itself is stuck.
Check the brake pedal free play. If the pedal doesn’t return all the way, or if the pushrod into the master is too tight, residual pressure won’t bleed off.
Inspect rubber brake hoses for bulges, cracks, or stiffness. Replace if original — they’re cheap compared to calipers.
Verify the parking brake cables move freely when released.
Consider a full fluid flush/bleed. At 240k, the fluid is almost certainly overdue and may be part of the problem.
It’s almost never 4 bad calipers all at once. Much more likely you’re dealing with old hoses that are collapsing internally or a master cylinder issue holding residual pressure in the lines. The fact that all 4 are dragging points to a system-wide restriction. Try cracking a bleeder on a locked caliper: if it frees immediately, that confirms fluid is trapped upstream. At 240k, a set of new brake hoses and a full flush would be my first move before throwing calipers at it.
