Progress Thread And so it begins....
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date
D
Enough screwing around, it's time to get serious.
Nightfire's official build thread is here.
I will update this thread periodically as I receive parts and as work is done.
Plans:
Induction/etc.....
Procharger D1SC kit w/ 4-core IC
42# injectors
Aviator 270lph pump
VMP HPX blow-through MAF
KB BAP
Diablosport MAFia
Motor.....
-Manley Street Master forged pistons (9.5:1 CR, standard bore)
-MMR forged H-beam rods
-Total seal plasma moly rings
-Clevite rod and main bearings
-Kellog forged steel crank
Misc....
17x10.5 17x9 anthracite FR500's
315/35/17 NT555R
Auto Meter tri-pod A-pillar pod
Auto Meter boost gauge
Auto Meter wideband A/F gauge
Auto Meter fuel pressure gauge
The shop doing the build will be installing the blower and building the motor at the same time (machining stock block and balancing rotating assembly). Initially I'll be shooting for whatever the max the fuel system can support. The procharger kit I got came with the 42's, BAP, and fuel pump. I'll upgrade the injectors and fuel tank later.
Well enough chatter, time for pics....
Polished D1SC with 3.2 pulley
Mishimoto 4core IC and boost piping
Hot-side piping (SC to IC)
Intake side w/ VMP MAF housing
VMP HPX5000 blow-through slot-style MAF
Miscellaneous parts:
-Aviator 270lph fuel bump
-SC bracket
-KB BAP
-triple pod A-pillar gauge pod
-idlers & 3.6 pulley
-Diablosport MAFia MAF extender
-FRPP 42# injectors
-Autometer boost gauge
-Autometer wideband A/F gauge
Anderson Powerpipe assembly
Manley 18cc forged pistons
MMR forged H-beam connecting rods
Total Seal rings
Other goodies that I've added in the meantime.....
17x9 17x10.5 anthracite FR500's
Mounted on some NITTO 555R's
Procharger Big Red Race valve
Only thing I'm waiting on are the rod/main bearings (which are in transit).
The car is going in on Monday! I can't wait to get her back :D
Nightfire's official build thread is here. Parts are now beginning to trickle in, starting with the biggest/most bonerific, my D1SC :D
Plans:
Induction/etc.....
42# injectors
SVT Focus pump
KB BAP
Diablosport MAFia
Motor.....
Forged bottom end (this is what I'm leaning towards)
-Manley Street Master forged 4032 pistons (9.5:1 CR, standard bore)
-Manley forged 4340 H-beam rods
-Clevite 77 P-series bearings
Misc....
315/35/17 NT555R
I came home tonight to this badboy waiting on my porch
Damn thing weighs a ton!
I'll post more/better pics of the whole kit tomorrow :)
What size pulley you running?
I've got a 3.6, 3.4, and a 3.2 pulley.
Im shooting in the dark here, but with my mods I think that I'd see 8lbs, 10-11lbs, and 13-14lbs respectively with those?
Nice!
May I advise that if you don't already have a trans cooler and done the J-mod, do those immediately. Your transmission will thank you later.
This setup with a good converter could easily be capable of 10s with enough traction. :nice:
Nice!
I've ALWAYS wanted to add a tranny cooler, just haven't gotten around to doing it. I will definitely be doing that here shortly as well.
Any recommendations for a canned baseline tune? I just need something to get the car started and to the tuner.
If you leave the stock injectors and MAF installed until you get to the tuner, it should run just fine. Just stay out of boost.
If you have to put the injectors and MAF on before you drive it to the tuner, you'll have to get your tuner to write you a tune for that. The car may crank and run, but that's about the extent of it.
When i installed my Kenne Bell, I had the stock tune with the 39lb injectors and a LMAF installed. Car ran JUST enough to drive it 25 miles to the tuner...... It died like twice on the way, but it still got there perfectly fine. No can tune needed.
I have to drive 250 miles :ack:
Try to find a friend with a truck, and trailer it up there instead. Theres no way I would drive 250 miles..
This...
I'm somewhat familiar with the KB install and swapping injectors on the fly isn't viable. If worse comes to worse, you should be able to rent a half ton truck and trailer from U-haul. It's easier if you have a buddy with a truck and just pay for his gas etc.
