D
Deleted member 38176
Enough screwing around, it's time to get serious.
Nightfire's official build thread is here.
I will update this thread periodically as I receive parts and as work is done.
Plans:
Induction/etc.....
Procharger D1SC kit w/ 4-core IC
42# injectors
Aviator 270lph pump
VMP HPX blow-through MAF
KB BAP
Diablosport MAFia
Motor.....
-Manley Street Master forged pistons (9.5:1 CR, standard bore)
-MMR forged H-beam rods
-Total seal plasma moly rings
-Clevite rod and main bearings
-Kellog forged steel crank
Misc....
17x10.5 17x9 anthracite FR500's
315/35/17 NT555R
Auto Meter tri-pod A-pillar pod
Auto Meter boost gauge
Auto Meter wideband A/F gauge
Auto Meter fuel pressure gauge
The shop doing the build will be installing the blower and building the motor at the same time (machining stock block and balancing rotating assembly). Initially I'll be shooting for whatever the max the fuel system can support. The procharger kit I got came with the 42's, BAP, and fuel pump. I'll upgrade the injectors and fuel tank later.
Well enough chatter, time for pics....
Polished D1SC with 3.2 pulley
Mishimoto 4core IC and boost piping
Hot-side piping (SC to IC)
Intake side w/ VMP MAF housing
VMP HPX5000 blow-through slot-style MAF
Miscellaneous parts:
-Aviator 270lph fuel bump
-SC bracket
-KB BAP
-triple pod A-pillar gauge pod
-idlers & 3.6 pulley
-Diablosport MAFia MAF extender
-FRPP 42# injectors
-Autometer boost gauge
-Autometer wideband A/F gauge
Anderson Powerpipe assembly
Manley 18cc forged pistons
MMR forged H-beam connecting rods
Total Seal rings
Other goodies that I've added in the meantime.....
17x9 17x10.5 anthracite FR500's
Mounted on some NITTO 555R's
Procharger Big Red Race valve
Only thing I'm waiting on are the rod/main bearings (which are in transit).
The car is going in on Monday! I can't wait to get her back
Plans:
Induction/etc.....
42# injectors
Aviator 270lph pump
KB BAP
Diablosport MAFia
Motor.....
Misc....
315/35/17 NT555R
-SC bracket
-KB BAP
-FRPP 42# injectors
Total Seal rings
