Progress Thread And so it begins....
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date
Props to you nightfire for not getting all butthurt at my comment. It is an awful lot of cash to dump into a car. I hope you are also focused on your future as well and not buying that stuff on credit. It is your business of course all I ask is that you think about it...
Nope, not purchased on credit :)
I'm somewhat familiar with the KB install and swapping injectors on the fly isn't viable. If worse comes to worse, you should be able to rent a half ton truck and trailer from U-haul. It's easier if you have a buddy with a truck and just pay for his gas etc.
Eh, if he's mechanically inclined, it shouldn't be a big deal to swap the injectors and MAF after he gets to the tuner. I could easily do it in 30 or so minutes.
Wow what a colossal waste of time and money, look back at this thread in ten years op and wonder what you could have instead done with it.
And he still has spent less money than you have on your Cobra. :shrug:
I had to go back and re-read. The OP doesn't have a KB... someone else mentioned it. My bad.
I finally got my 315 NT555R's and got the wheels on. These things are absolutely gorgeous! I find myself staring out my front window at them quite a bit.
The 315's are WIIIIIIDE! The car looks like a steam roller from behind. I LOVE IT!
They barely fit in my office chair lol
Also got my wideband gauge
Reactions: mustangman9812
Finally got around to fixing the cracked intake. It turns out that a tiny section of seal around the thermostat port had broken. It's a damn shame that such a small thing has to lead to replacing the whole damn intake :nonono:
Badass.
The only thing I will be critical about is your choice in pistons, fuel system and not adding a meth kit. With the extreme heat we see here, and you being in the desert, keeping the IAT's down is critical. I would not rely on just a BAP in the long term, and get some more octane and cooling to the car through meth.
Glad to see the car finally being built. Feck the haters like KT dbag, my car is just as old as yours and I'll be building it next month too.
Thanks, Dr. Phil and Suze Orman at the same time. Maybe I'll use your advice... Oh wait, I'd always be slow like you...
Badass.
Really? I thought Manley was about as good as they come. I haven't purchased the rotating assembly yet so Im still open to suggestions.
As far as the fuel system goes, the setup Im going to run is just to get me started. I scraped the focus pump and bought an Aviator pump. When I can afford it, Im going to overhaul the fuel system. As for meth, the more I read about it the more I like it. Im pretty sure I'll run a kit in the near future.
My bad, thought you were running "Mahle" pistons. Manley are fine. I prefer Wiseco or Diamond pistons. I'd run 10.1:1-10.4:1 compression personally. It's amazing what 1 point in compression can do to the bottom end fun factor of a centri blown car. My last setup was 10.5:1 compression, and I might go up to 10.8:1 on my 347 build I'm starting. Meth with a spot on speed density tune is the best route IMO.
