I want raise my compression from 9:1 to 10:1 in my 96 Explorer 5.0 with GT40 heads which is for street use only. I don't mind using premium fuel in my carburated 64 Falcon. I will be taking the block to the machine shop and have it bored 0.030 over and deck the block. I will also take the heads to the machine shop for new valve guides and a valve job. The machine shop should know how much material to remove to raise the compression to 10:1. I believe the GT40 heads are 65cc. In 1996, Ford switched over to thinner metric piston rings (for lower friction?) and for my Explorer Engine, I think I can use either the standard 5/64" or the 1.5mm piston ring pistons. All 302 up to 1995 used the 5/64" piston rings. The metric Explorer piston with 1.5mm piston ring has Compression Distance of 1.595. The standard piston with 5/64" piston ring has Compression Distance of 1.599.
Speed-Pro Hypereutectic Piston and Ring Kits (5/64" x 5/64" x 3/16") $170:
Speed-Pro Piston and Ring Kits Z8KH273CP30 - SummitRacing.com
Speed-Pro Hypereutectic Pistons (1.50mm x 1.50mm x 4.00mm) $118:
Speed-Pro Hypereutectic Pistons ZH816CP30 - SummitRacing.com
Sealed Power Plasma-Moly Piston Ring Sets ZE458K30 $71:
Sealed Power Plasma-Moly Piston Ring Sets ZE458K30 - SummitRacing.com
TFS Cam: TFS-51403001 - Duration at 050 inch Lift: 221 int./225 exh. Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh.:
Trick Flow® Track Max® Hydraulic Roller Camshafts for Ford 5.0L TFS-51403001 - SummitRacing.com
Can anyone please tell me how much material needs to be removed from the GT40 heads ?
Any issues with valve clearance using the Speed-Pro Hypereutectic Piston and Ring Kits Z8KH273CP30 with TFS Cam using 1.6 Rockers ?
Is it going to make any difference if I use the pistons with the 5/64" or the 1.5mm piston rings ?
The 5/64" version is cheaper since its available as Pistons and Rings set and was used on all 302 except 96+.
Thanks
Waid
Thanks
Waid
