Double Din Radio
Pops Fun
961
14
59
Cincinnati, Ohio
My son and I started the radio install... Long day.. 10;30 TO 6PM.... 3 or more hours left
Here are the parts and what is done to date.
Bought radio used $200.00 Came with Nav., Sirrus module, Parrot (bluetooth) module, bought Ipod module $106.00. Ipod cable installed in Glove box, now I will have to buy an Ipod ... Grandson says it's the only way to go. :)
All modules wired and under passenger seat, just laying there now.. ??? Will have to work on that I guess.. Well off to church later..
View attachment 136190 View attachment 136192
Bolted side view
Bolted together upright
May need a trim piece..
View attachment 136198 \
Piece of iron bent and bolted to existing Bracket inside dash... Foam tape will be added as needed for support,
Ok, More after Wednesday... used radio was short the cord connecting to our amp, so had to order a Scosche SLC4 Four-channel line output converter replacement piece to go between the radio amps and the car amps. Crutchfield is your friend will set you up with adapters and cables.
Good work. I sure miss the Pioneer double din I had in my 2006GT. Use to watch movies on the way to / from work.
Finished... Still a few tweaks...... have to match the bezels better..... works pretty well another 7 hour day....
Touch is the way to go. Pretty easy.
Nav. DVD movie, Bluetooth, Ipod
In the knob holes are Blue tooth control, SCT chip/tune selector, and a cig lighter
