gearing is everything
Leverage is equivalent to torque.
A longer breaker bar increases your "leverage" and allows for greater "torque" when breaking loose 460 head bolts, torqued to 140 ft lbs..
I get what you're saying.. just nobody anywhere measures torque from a vehicle like the OP would like to.
Off topic - can you post some pics of your car madmike? I've seen bits and pieces in threads but I can't quite figure out what you've got there.
This whole thread was started by some guy that got drunk and logged in to post some babble about some babble he read somewhere else and your arguing only gives validity drunk babbling. Or maybe we're all drunk on here babbling about babble. Like a bunch of drunk guys with a laser pin playing with a dog. It's all pointless. My babble right now is just useless babble about other peoples babble and now i'm going to get back to work since i'm on the clock and shouldn't be babbling.
to the OP, my screw gun puts out more torque than your screw gun. I'm cooler than you so :zipit:
:rlaugh:
Must...not....join...in...must...not...
ALRIGHT!
I can't resist a tech argument, no matter how half baked everyone seems to be, or even with the looming threat of this all being a troll thread.
1. If gear reduction/multiplication/whatever isn't the same thing as torque, then I learned things all wrong in engineering school.
2. I ain't no expert on the subject, but from what I know, chassis dynos have a big ass drum in them. The dyno's computer knows how much this drum weighs. You drive your car up on this drum, strap in, and lay into the throttle. The computer measures how quickly your car accelerates this drum, all while monitoring your engine RPM. It then calculates how much power your car makes, very much in the same way drag racers estimate the power their cars make based on how much their car weighs (think: drum weight) and their trap speeds (think: how fast you managed to accelerate the drum). SO now the computer knows how much power your car makes and at what RPM- from that, it is a pretty easy calculation to determine engine torque.
So, the torque on a inertia-based chassis dyno isn't actually measured at the rear wheels, but instead backwards calculated from power and RPM. Gear ratios are ignored, but obviously, REAR WHEEL torque IS a function of engine torque AND gear multiplication... But the dyno doesn't measure that.
Flawed dyno argument is flawed.
Reactions: hoopty5.0
Reactions: Mr. Snrub
ALRIGHT!
So,...what you are saying is that my shredded arm is a flawed method for measuring the torque of my Dewalt drill?:shrug:
And what is "rear tire force? Where does it come from? Oh that's right.............it comes from the torque that the engine makes..........hmmmmmm.......maybe that is why on a chassis dyno you get 2 power numbers.....rwtrq and rwhp. Yup rear wheel torque is what is measured on a chassis dyno, the same torque that came from the engine. Calling a horse by a different name does not change the facts, and that is torque at the tire does not change.........period. It does not matter what gear you are in. If your argument was only about gear reduction...........well, then we would not have any disagreements. Gear reduction and torque are two different animals completely.
I guess we will never be on the same page, but torque and gear reduction go hand in hand. By using the engine torque with gear reduction we can make tons of usabable torque to the ground to make our cars faster or maybe I should say quicker.
I kinda get what dude is saying, and dispute everybody stating that torque is torque
Even using a Dewalt 24v drill as an example, the high setting offers speed in exchange to trading off the ability to turn a Gi-honkin 2" auger bit at that speed.
Put that sucker on low speed by effectively reducing the gear ratio, and God help your broke ass arm if you hit a nail with that same Gi-honkin auger bit chucked up.
The lesson that your shattered forearm is testifying to is that torque just got multiplied exponentially by a simple gear change.
Nothing got changed electrically in the drill motor to increase it's output, so how the hell did the same drill that I could drill a hole on "3" while holding it w/ one hand, just frag my forearm after I changed the speed setting to 1?.
I'd be curious to see what a chassis dyno pull would be on any engine given the rear gear ratio could be reduced to a 1:1, and then compare the same combo w/ whatever "normal" rear gear ratio typically ran against it.
Thankyou!
All you have to do is do the math toqrue x primary ratio 1.5:1 x3.0 1st gear x3.0 final drive ratio .
What do you get? Besides my bike does 12.10 in the quarter How fast is your car?
NOOBZZZ!!! Squeaky just changed a "gear vs torque" argument into a "power vs weight" argument!!!
Can he do that?:fuss:
