What would be the downside in using the cheaper Flowtech headers?
I had them for my 4.6. The build quality was pretty bad, but for me I thought I was gonna have to modify them to fit anyway, so that really wasn't that important.
If you are wondering why you should use them over a more expensive, better built, coated or stainless set, the benefit is obvious. Better fit, finish, performance and to most, longevity become the reasons to spend more money on a set of long tubes.
The last point should be the one you look at most, especially since you're paying somebody to install them for you.
BTW,.....putting headers on a 5.0 in a fox mustang is pretty easy,...why are you paying somebody to do it?
Reactions: madspeed
why would you knowingly put crap parts on your car, especially if you are paying someone else to do the install? IMO, if you are strapped for cash look around on the boards for used set of FMS shorty headers. You can get them for about $100 or less and they are the best shorty headers period. I found a set of used ceramic coated ones for $75 on the corral. Throw them on with a set of new felpro gaskets and SS 1" long allen head bolts which you can get at Tru Value with lock washers and you are set.
Summit brand longtubes are made by Flowtech, which is a Hooker company.
129 bux...
http://www.summitracing.com/parts/sum-g9030/overview/make/ford
As far as quality, yeah, high dollar headers are higher quality, but that is a relatively new thing.
These headers are no different than what you would get 20 or more years ago.
Painted, not coated, mild steel, not stainless, 3 bolt flanges, not ball and socket.
My son has the Summit labeled long tubes on his car, and they act like any other 'basic' header acts throughout history.
For they price they are good... I wouldn't spend a dime on shorties myself.
I have a set of these myself, and I plan on putting them on my 87 after doing a high quality re-paint. Stripping the factory paint is the toughest part. I got mine "used" from a swap meet for $50, but they have never been on a car. Just lots of 'shelf wear'.
One thing to note about painted headers, it doesn't matter who you buy from, the paint sux.
NO header manufacturer out there uses quality high temp paint. It's a cost saving thing.
If you want paint to last on headers, I don't care which brand, you MUST strip the factory paint, clean the header very well, including a degreaser, then, without touching the headers with your bare hands (oils), paint them in several coats of high quality BBQ black or header specific paint. Then, without getting any oils or such on them, heat them up to cure the paint. If you get any fingerprints or contaminents on the surfaces before curing the paint, it won't hold up.
You know, you could get a $1000 set of headers, anything less is "crap" I suppose, but if you can afford that, why are you driving an old Ford?
I mean, come on... These "crap" headers are what people have been using for decades without too many issues other than surface rust.
If it makes anyone one feel better my rather expensive kooks headers are rusted beyond belief, at the end of the day they work no different than a set that is not rusted. Op, buy what you can afford, no sense in stretching your pockets..
No where did I mention spending $1000 on a set of headers. All I said was if the OP didn't have the money to buy a good set of new headers, he could probably get a better quality set of headers and H pipe used. I try and put the best parts on my cars, but that does not mean I pay top dollar, or even buy them new if possible. I've bought everything from intakes, exhausts, superchargers, etc. all used that otherwise I could never have afforded. I buy new when I have to. These cars have been around 20 years and quality used parts are dirt cheap. I see LT headers and H pipes for sale on CL, Ebay, and message boards all day long for 1/2 the price of new.
As long as the OP knows that these are mild steel that tend to rust because the paint will peel and burn off and he is happy with his new headers looking rusty, then they are a cheap alternative to $300 and up new ones. It sounds like he is not the type of person that wants to start stripping the paint off his new headers and then repainting them.
Is there any reason why he is going to LT headers vs. short tubes as he is not racing and the majority of hp gains with LT are in the higher RPMS. The LT may give him and extra 10hp maybe but they are a PITA to install and interfere with starter, clutch and other replacement of parts. Again, just my .02 but it's not my car or my money and opinions are like elbows- everyone has them.
I'm surprised to hear that. The Kooks on my last car after 6-years and several thousand km looked as good the day I sold the car as the day I put them on. The were Jet Hot coated though.
I've got BBK's (ceramic coated as well) ready to bolt onto my Fox in the next couple of months. I only hope they hold up as well as the Kooks did.
This is completely untrue. Long Tube headers have a far superior scavenging effect and provide gains throughout the entire RPM range...bottom, mid and top. More so than shorties, that make most of their gains in the upper ranges....if at all.
Yes, they can be a PITA to install, but that's just the nature of the beast. Short tubes (while easier to install) also provide minimal benefit in return.
Reactions: ratio411
I have been running flowtech headers for about 5 years on my GT with no problems with rust. I just used 2000 degree exhaust paint.. i sanded them and sprayed them flat black.
any header that isnt a good quality stainless is going to rust. Doesnt matter if they cost 100 or 1000. For someone on a budget, the flowtechs are a good deal if you go into it with the mindset that they may require slight modification to make them right
Wrong...
Shorter primaries peak at higher rpm, longer primaries peak at lower rpm.
Longer primaries also = more torque throughout the rpm range.
From a test of ST vs. LT headers by 5.0 magazine.
http://www.mustang50magazine.com/techarticles/29618_short_long_tube_headers_test/viewall.html
Show me where the huge pick up in HP and Torque are throughout the rpm range and where ST peak at higher rpm in this test. The OP said he has a mild rebuilt 306 and is not racing the car. LT are great and I have run them on many cars. I just don't think they are worth the hassle and expense for a mild combo.
Those results are not typical. Long Tubes generally best short tubes across the board.
In any case, did you read over the text of the article you posted? With the exception of the abnormal horsepower differences, they pretty much emphasis the point ratio and myself were attempting to make....
With these results in hand, the long-tube headers and H-pipe were removed, and the short-tube headers and H-pipe were installed. The results were interesting: the engine gained nearly 8 hp, and a little over 5 lb-ft of torque at 3,500 rpm over the long-tubes. However, the long-tube's torque and horsepower curves lasted longer (see dyno charts), suggesting that these headers would indeed make even more power over short-tube headers if used on a more modified engine. This is due to the fact that a long tube header can make use of the engine's exhaust pulses to "pull" exhaust gas from the cylinder, providing optimized scavenging. A short-tube header, with its much shorter primary tubes, simply does not have the same advantage.
Reactions: ratio411
Brian, I read the article and understand what they are saying. However, they also said the following:
more to selecting a header than the power it makes. If you are making 350 hp or more, and live in a state that allows the use of two-cat H-pipes or off-road H-pipes, then the long-tubes are the header that will make the most power. However, if you have a stock or mildly modified car, live in a state that requires the stock H-pipe, or just want the simplest installation possible, the short-tube would be the
I may be making a wrong assumption, but it does not sound as if the OP is making 350 hp. On a mild cammed 306 I would think the shorties are more efficient in getting rid of the exhaust vs. the long tubes. Granted the scavenging is not as good but that doesn't come into effect until higher rpms. Maybe he can provide some greater details?
Also, an interesting read on short vs long tubes on mild builds
http://www.physicsforums.com/showthread.php?t=208674
However, as again the OP clearly stated he is not racing the car, my points about the extra money for install, clearance issues and hassle about clutch, transmission, starter repairs remain. Remember, he is paying someone for the install and I would assume the same for any other repairs. We all know the potential problems with clearance with various other components, ground clearance.
Great discussion by the way that has been around for years. Like I said earlier, everyone has their own opinion and it comes down to doing what you want with your car and your money.
Cheers
Thank you guys very much for your replies. I should have included more information. So here it is. I do not race but i like a strong street car. I cannot work on the car myself because I live in an apartment and i don't have good tools or a place to work. I already have BBK shorties. I have an all forged internals rebuilt 306 from a '94. My friend had the bored block already, he did the work i just bought the internals. i wanted the car smog legal so i kept the smog pump and cats. a few weeks ago the smog pump locked up on me. so now I'm thinking of dropping the cats and SP and going LT+ x-pipe.
You are all correct though i don't want to deal with them again so i will buy the BBK LT on caigslist of Ebay hopefully less than $320.
here are some I'm looking at:
http://www.ebay.com/itm/HOOKER-1-1-...Parts_Accessories&hash=item3a7a5ee8ee&vxp=mtr
http://losangeles.craigslist.org/sfv/pts/3723406723.html
http://www.ebay.com/itm/1979-1993-F...Parts_Accessories&hash=item3a800a4876&vxp=mtr
Stock H/C/I ?
If you are going LT, unlike ST headers, make sure you get the correct ones for your transmission - stick vs. aod.
For stick
http://www.americanmuscle.com/bbk-longtube-79931.html
Notice these say they will fit an auto.
http://www.americanmuscle.com/bbk-longtube-header-automatic-7993.html
Personally 1 wouldn't go with 1 1/2' primaries.
