Drivetrain Speedo Gear? 87 Gt, T-5z, 3.55, 255/40/17
Bill Cool
Previously 87MustangGT
1,268
Seymour, CT
I've got an 87 5.0 with 3.55 gears. I recently installed a rebuilt T-5z, and plan to install some 255/40/17 rubber on 17x8.5's. What speedo gear will I need?
As an aside, I assume (since the LRS website states "Requires a 1/8" spacer when used on all 79-86 cars or 87-93 4cyl cars.") that these will fit my GT without rubbing...?
Is this regardless of the drive gear? And, doesn't overall tire height fit into it? Based on the link below, it seems like 255/40 might be just outside a stock height tire (255/45s would be perfect, for comparison)
http://www.discounttiredirect.com/d...1987&mk=FORD&selectedModel=MUSTANG&vid=006900
Considering you mention you rebuilt the T-5Z...which speedo drive gear did you use? Black 8-tooth, or yellow 7-tooth?
I didn't personally rebuilt the tranny...and I didn't check before it was installed. What, aside from the obvious, is the difference between the two drive gears? And which driven gear would be appropriate depending on the drive gears?
