Brakes Is This Why I Don't Have E Brake? Pics
5point0stang88
205
15
29
And how easy is it to fix? I might attack it when I install my Eibach drag springs and upper lower control arms
Sent from my SPH-L720 using Tapatalk 4
There's a loop on your caliper. You'll pull that spring away from the metal tip and the steel wire will fit through the loop on your caliper. Then the spring will press the caliper which in turn will press the metal tip. Sorry if that sounds confusing. I'll take pics with my car tomorrow if you need.
Reactions: 5point0stang88
Thank you a lot. It sounds easy and I'll appreciate the pics
That's a drum brake e-brake cable. So if you have rear disks, it's not going to work. Are both of them zip tied to the sway bar?
If you have rear disks, you'll need completely new cables.
^^ I heard that. Would be nice not to have to remember to leave it in gear all the time.
I'm pretty positive I have drum. I'm gonna laugh if I have disc lol I wish. But yes I always have to turn the wheel extreme left or right for it not to roll back if I wanna get out with car running :/
