Those of you running electric fans on your foxes, what are you using for a catch can? Also, is there a way to fool the sensor so the low coolant light doesn't come on?
Thanks!
Thanks!
My catch can split and I haven't run one in years![]()
That's exactly what I did. Been 20 years and no issues. I just left fluid below the first row of tubes.Did you just cap off the neck tube of the radiator?
Can is just there to catch any vented Steam. If your radiator cap is on good working order and your cooling system is working as it should nothing is supposed to come out.
I bought a Canton Overflow Tank that accepts the Stock Low Coolant Sensor.
Why is there a Full Hot and a Full Cold line then? Just curious. Thanks to the replies so far. I guess it's safe to remove it altogether while I come up with a solution.
high tech! I actually think a buddy of mine gave me this overflow years ago. I just recently installed it and was doing the same run the hose down to the lower core support for years without problems
