What Octane Should I Run Before Heading To Dyno?
Has been tuned when motor was fresh. But since then had intake and exhaust work but same heads. Reason for going back is to check a/f ratio. Hasn't been runnin to good lately. Smells rich, gassy ya know
Have you dumped the codes to make sure there isn't a sensor or wiring problem present?
Going to the dyno tune without dumping and fixing the codes is a lot like going out the front door and leaving you pants hanging in the closet. You haven't done everything you need to do to be prepared to go.
There may be codes that will affect your tune. The turner will charge you $$$ to fix them so that your car can be properly tuned. It is possible that the problems you are having are code related and you can fix them much cheaper than a tuner will do it.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30-$36.
attachment.php
attachment.php
What to expect:
Alternate methods:
The Equis-digital code reader link isn't working FYI or it isn't with my iPhone.
Reactions: A5literMan
are you getting a dyno tune or just goingto see what she's got? Many tuners won't touch it if there's fault codes
A little of both??? well it had to get tuned after the rebuild awhile back just to get er running due to the cam. At that time it had old rusted out flowmasters due to sitting awhile prior to rebuild. It now has a lil intake and exhaust work so don't really know if it "needs" a time or if they could get anymore out if it w a tune but figurd since a new tune would be free minus dyno time might as well make an appointment and see what happens. But before I go I'm gonna see if it has any codes. Smells rich since the a/c was fixed. "Gassy"
