Ball Joints
tulsadrags
I have a 1964.5 mustang that has disk brakes in the front and rear. I have a problem with lower ball joints in the front. I have ordered two sets and both are (100) hundred thousand two small. Any ideas where I might find some information?
Thanks in advance
Bill Moore
918-695-8279
[email protected]
Thanks in advance
Bill Moore
918-695-8279
[email protected]
what spindles does have ? there is a part # on them
ok this should answer all questions on ball joints .64 -66 6 cylinder and v8 use the same ball joints for the top and the same ball joints for the bottom.i compared a set of 64 1/2 6 cylinder with a set of 66 v8 and they are the same so 64 1/2 v8s will be the same as well . there is a kit i believe that allows a 5 lug hub to be mounted on a 6 cylinder spindle however the spindle nuts are different ,the 6 cyl. is smaller .and the tie rods ends for the 6 are smaller than the v8 but ball joints are the same.
@tulsadrags are the ball joints you have been trying to big or to small? you may be trying 1970 and they are larger.
