At what point does it make sense to run a two speed power glide over a three speed auto? It seems to me if there is enough power to blow away the hides in first, installing shorter rear gears (3 something instead of 4:11) would still allow 3 areas to be in peak power/torque at the track. It will also lower your highway rpm if you went on drag week or a cruise. Going to the extreme, a CVT would be ideal if the rubber bands were strong enough. You could always have the motor at peak HP or torque. What am I missing here?
