I ordered clevite p series rod bearings and i noticed that they have an oil hole in them where as the stock ones didnt . Is this a big deal ? I wouldn't think it is but i wanted to make sure .
CB-634 P-1 - these are my .001 over bearings and then i have standard size as well to get the clearance right . As long as the hole is no biggie i am satisfiedNope no big deal. There made for aluminum rods with a dowl pin. Usually u can order with or without down hole. Should be a D in the part number.
Ok...how does a oil hole in a rod bearing help with a floating wrist pin at the other end of rod? How in the hell does it help crank case pressure? What surfaces are moving against each other? The rod bearing is riding on a film of oil between the crank and bearings. I've built enough race engines to know better...
Scott
Scott
Scott
