- May 13, 2006
- 83
- 3
- 9
About 5 years ago I had removed my entire interior to have subframe connectors and upper and lower torque box reinforcements welded in. I currently have my interior out for some surface rust on the passenger side floor from water that leaked in. I completely forgot about this crack, but at the time, I had just drilled out the ends of the crack to keep it from spreading. This is behind/underneath the rear seat BTW.
This is the worst crack in the entire car. There are a few other much smaller, much more mild cracks. There is a good bit of separation there, so do you guys think it can be welded up with no problems? Or should I just leave it be? I have no welding experience, so I don't know what to do with it. I'm assuming the spot welds around it are from the upper torque boxes which had began separating. What do you guys think about those?
. I am becoming a perfectionist in my old age
. The car will not move until I get the floor pan surface rust taken care of anyways. This car has no rust anywhere except there and a small spot under the hatch, where it will also be fixed before it sees any kind of precipitation. (NEVER any snow/salt though!!)
