Build Thread Want To Blow 5 Years And $50k On A Foxbody? Step By Step Instructions Inside!
Do you think once the front suspension articulates it will rub the fenders? Are you running fox arms?
The tires sit inside the fenders a little more than those pictures lead you to believe. The fenders are also rolled, so I don't anticipate any problems. I am running fox length MM a-arms. I was more concerned about the rears rubbing, but the car squatted so hard during the dyno pulls that it put the tires into the fenders and I haven't noticed any signs of contact anywhere.
how pumped are you going to be cruising on a nice fall night with the windows down? :banana:
I can't wait. I'm real excited to just rip it around the block a few times once I get my fuel pump back and fix my return line that developed a "leak".
I was staring at the car tonight for a while (because that's what I do and I'm critical of my work) and decided that I'm not happy with the gaps for the hatch. I was looking at older pictures of the car and it looks like it fit better back then. I got sick of messing with the hatch when I put it back on because aligning it was such a tedious task, but it could definitely be better. Looks like I have something to work on tomorrow night!
I got the fenders and doors setup pretty well, especially considering that the fenders are not original to the car. All those gaps look good. That hatch though...
Your version of land a plane in there and the amount of actual gap are probably perceived much differently by anyone looking at the car other than you. You take perfection to a whole new level! Very well done
Although honestly if I spend that much time effort and money on my fox, I'm going to make it better then perfect too, and you are your own toughest critic, so the day that it is perfect in your eye is the day that people's heads explode when they see your foxy fox
While I'm certainly no chemical engineeer, my understanding is that leaded fuel was designed as a lubricant for the valve seats in early days to prolong their service life. It was also determined to add noxious pollutants to the air, so it was banned in the 70's as a motor fuel for vehicles driven on the street. Race gas, and Av gas still have lead in their chemical composition for the same benefit, but are not outlawed due to a comparably limited usage vs the millions of cars on the streets. Using a leaded fuel in a car equipped w/ catalytic converters is a sure fire recipe for a clogged converter.
Av gas has detonation inhibitors that actually slow down the burn, and make it's usage in a race car/high compression engine less than favorable when compared to using the equivalent octane rated automotive gas (i.e. Sunoco 260).
Alcohol based fuels, (like the E85 I'm considering) burn even slower than AV gas, at at a much lower temp than gasoline. It also takes considerably more of it to do the same job.
Cars running E85 will get significantly poorer gas milage as a result. While fuel consumption is a definite con, the fact that it burns so cool makes the engine run significantly cooler, to the extreme that race cars powered solely on methyl-alcohol do not even need a radiator. The other, obvious pro is the potential 100+ octane rating. It's a very clean burning fuel as well, so the typical carbon, and crud that are by products of gasoline, is non-existent when using E85
Back on the con side, it's corrosive, and your equipment has to pump more of it. There is a very high percentage of moisture in E85, and that moisture typically ends up fouling the engine oil much more quickly than a gas fueled engine. That makes the stuff not compatible w/ every filter/pump/regulator/lines currently in use on a gas powered vehicle. That makes for a little homework to determine what has to be changed/upgraded when considering it as a fuel.
Now, I don't know how I did on my armchair chemistry lesson, but that is how I've always seen it.
e85 ftw!
Thanks dude. It could fit a small plane, like a Cessna. It's not 747 bad or anything like that. Haha
I stopped at the notary and registered the car. Should have my antique plate in a few weeks. This state is great. Just fill out a form, pay $150, and you get a lifetime registration and no safety or emissions inspections ever. They used to require 4 photos of the car and it had to appear completely stock, but luckily they did away with that 2 years ago.
Antique! :lol:
..fuk I'm getting old
:think:
My little fuel line issue is taken care of.
Reactions: RaggedGT
You gave them a pretty much brand new one so what you get back should be in kind. I have a bunch of stuff that's been sitting around now for almost a year that I buy as I get money and set aside. Hopefully everything works out well, especially since most of the stuff won't be installed till mid winter or Spring 2015. If there are hiccups then I hope Summit and LateModel treat me well as there is lots more $$ to be spent on my Coupe.
Reactions: stangboy
