A Little Off Topic
RallyST
11
But the bronco used a 302 as well. Just curious if you guys could tell me what I would need to preserve the 4x4 if I was to swap a coyote motor into a bronco?
Yes lol. And if anyone has transmission suggestions. Done some research but I'm thinking the coyote won't work well if I wanted to preserve 4x4
Ohh so your main concern is being able retain 4 wheel drive? What are the new trucks using? I'm of very little help but I'm sure it could be done but I imagine it'd be pricey. The coyote and the pushrod 302 are completely different animals. If you're wanting more power it'd be cheaper to do heads, cam, and intake.
Unfortunately the motor in the bronco is shot. Cheaper to swap then pay someone to rebuild because I have no idea how to rebuild lol
So that leads to my next question, if I was to just swap the 5.0 to my fox, will the 302 from the fox bolt in the bronco?
Yes. Little things are different like the firing order but it'll bolt in. If the fox 5.0 is stock then you'll loose some torque in the low rpm's due to the heads. If you're wanting to "go muddin" you wanna make power at a lower rpm. How often are you going to be spinning at 6k rpm unless you're stuck. Ya know what I mean?
If you want the coyote swap your best bet would be the complete drive train from a new f150.
Swapping in a warmed over 302 h.o would be a much cheaper alternative and if you score an explorers 5.0 it's worth about 60hp over what came in the bronco.
The e7 heads on the bronco abd mustang engine are identical. Difference is in the camshaft and the intake. With truck gearing you won't even notice the hit in the low end.
Reactions: RallyST
Good answer good answer
Reactions: RallyST
Same motor from a 98 explorer?
