What year is the car? The newer t5's are stouter than the early models. get a RAM clutch and a new cable, maximum motor sport or Ford all other cables will give you headaches - the trans guy can install if its beyond you.... That'll give you great clutch pedal feel, and don't worry even stock and tired the fox will do a burnout with no effort
Valve cover gaskets are a royal pain in the 5.0 you have to pull the intake upper half to change the passenger side - bolts are under the 5.0 intake badge plate you need allen wrenches to remove the cover plate take your time the get stuck from time..
MAF - unplug it and unbolt the 2 bolts holding its bracket to the shock tower - its now free, so dont let it fall removing the bolts...
go over to the side yard and using the bracket as a handle spray the MAF really well inside and out with cleaner - dont mess up the screen inside but be sure its clean and no little cr*p on it like leaf debrise etc reinstall, Then spray the mess outta the Throttle body, be sure you get behind the plate to clean the stuff thats attached there...
You probably know all this, but having a fox 5.0 these procedures become second nature / annual events.
Welcome to the World of Fox Mustangs!
