Trick Flow Heads Part#
krazedstang
670
278
104
Streamwood
Does anyone know where Trick Flow puts their part numbers on the heads? Only thing I can find is TFS-SBF-1, and according to Trick Flow I'm supposed to find TFS-51400613 or TFS-51400614 to determine if it has the 3/8 studs or 7/16's. Any info helps. Thanks!
Many of the tfs heads don't have a part number, I just went through this with the set I have. You take that number which is a serial number, call tfs and they will tell you what they are and when they were made.
My serial number was stamped or engraved above the exhaust ports.
Thanks I'm pretty sure I know which number you're talking about.
