Sorry about that, from what i know it is still a stock air meter there are no mods other than the cai, it is a fender well kit i have not tried going back to stock but i will be cleaning the mass air meter today and then i will install my stock back if it doesnt work.You don't give many details, is it a fender well kit or an open filter in the engine bay?
Stock mass air meter? Some aftermarket ones don't like cold air intakes.
Did you try reverting it back to stock?
Did you oil the hell out of it? Sometimes the oil gets on the mass air meter.
Putting your car info and mods in your signature helps us, help you.
yeah looks good but damm i hope i dont have to take it offBut does it look good? On a stockish 5.0, the ones with test equipment have told me that's all an aftermarket CAI is good for.
my temp gauge says normal but i feel like my engine is getting hot way too quick compared to before, my CAI also gets real hot is this normal?The header gaskets will smoke and smell for a short while.
The oil gauge is crapshoot, a better gauge is the only real solution to know if you have an oil pressure issue.
The temp goes up too quick or too high?
1. I don't belive you have a maf issue.my temp gauge says normal but i feel like my engine is getting hot way too quick compared to before, my CAI also gets real hot is this normal?
ugh damm i was also thinking that it might be a vacuum leak in those two places, i will check it before i drive it back to the shop that did the work so that if there is a leak they cant just blow me off and say everything is fine. i told them to check for vacuum leaks prior to me picking it up i guess they didnt check1. I don't belive you have a maf issue.
a. If the maf was dirty or broken the car wouldn't idle.
b. While yes the filters come pre-oiled it's been sitting awhile before it gets to you so it's not dripping wet like after one re-oils it at home.
c. Unplug the maf and try and start the car. If it won't start or it starts for a second and dies your maf is working.
2. Heat and high idle. I bet you have a vacuum leak at either the header gasket or valve cover.
3. CAI and sluggish. It could be that maybe you were expecting more out of it. As someone else mentioned the main purpose they serve are for cosmetic purposes. They manufacture hp claims are bogus. When K&N filters hit the market they claimed a 25 horse gain from their drop in the box pannel filter. I guess the cat's outta the bag, now the commercials claim they are good for the environment.
Oh and the oil pressure gauge- an old oem one will wander all over the place.
Atta boyugh damm i was also thinking that it might be a vacuum leak in those two places, i will check it before i drive it back to the shop that did the work so that if there is a leak they cant just blow me off and say everything is fine.
To be honest, i threw my BBK CAI in the trash and put the stock one back on. It began to rust up on the surface after a while and i got sick of polishing it. Also, it got VERY hot after a good drive.
Stock airbox and drop in K&N is really all you need. The BBK kit does look prettier but in terms of a horsepower gain, the stock airbox is decent
Nor the valve covers? Headers and valvecovers were the last things messed with before the high idle.The headers aren't causing a vac leak. Go through the surging/high idle check list that's posted here in the Tech forum. My guess is it's a sensor. Run the codes! And post back.
Just got home from a 12hr shift i will try and run some codes before bed because this is really getting to meThe headers aren't causing a vac leak. Go through the surging/high idle check list that's posted here in the Tech forum. My guess is it's a sensor. Run the codes! And post back.
