I looked at the archives first, couldn't find anything specific to my question:
I've got the driveline from a 91LX in my 67. PO had it custom-tuned with an older style chip (not Diablo or SCT). I'm basically running the same setup, with the exceptions noted below:
If I'm going to need to tune it, what setup should I use? I'm not wanting to become a guru on tuning this motor, I want set and forget. Money is an object, but I want a reliable setup. The only shop I know in the area is Power By the Hour--they won't even look at the car unless I go Megasquirt.
I'd appreciate your suggestions, and the reasoning behind them.
Thanks!
Greg
- 5.0 stroked to 347
- TF heads, 2.02 intake valves
- TF Street heat intake
- 75mm throttle body (was 70mm when tuned)
- 30# injectors (was 24# when tuned)
- 76mm MAF
- F303 cam
Thanks!
Greg
