Blower Belt Walking
JD1964
there is enough sticking out to grab on to
3,449
1,534
194
Maryland
The belt at the blower pulley is walking forward one grove. Still drives fine but I dont like this. I followed all instructions installing the V3 kit. I did go to a larger crank pulley and had to buy a new belt. The kit came with a Goodyear Gatorback belt. The replacement I got was a Dayco. Maybe that's the issue. The belt is tight enough but still flops around a bit, even at idle. Maybe it's just crappy belt. I have a Gatorback on the way. Other than checking alignment and such, what things can I look to for a solution? I'm not crazy about the plastic tensioner that came with the kit.
get a gatorback belt. Dayco's are crap. DId you take a straightedge to the puleys to see they are aligned proper?
I don't see how I'd be able to use a straight edge. The crank pulley is 8 rib and the blower is a 6 rib. Not only that but there's no room between the crank pulley and rad fan to even put a straight edge.
....and, there's only two groved pulleys in this issue. The crank and the blower. So without a third groved pulley in the run for a point of reference, how would a straight edge give an accurate measurement?
Reactions: hoopty5.0
How did you align the 6 rib and the 8 rib pulleys? Are you not wanting to void the blower warranty by removing and upgrading the pulley to 8 rib?
I've seen plenty of guys run the 8 rib lower pulley with a 6 rib blower pulley without issue. This will not void the warranty on the blower either as the blower pulley has not been removed.
1 of two things come to mind, The belt is too loose or there is an alignment problem. If the balancer has been off the motor before, ensure that it is seated all the way on the crank. I have in the past had to shim the blower to get everything to line up as well. With the variation between cylinder heads (this is what the blower mounts to) there is always the chance of misalignment. The kit is "designed" to work with "stock" cylinder heads and even the ford factory will have some variation on the end dimension of their cylinder heads. What you are experiencing is not totally out of the norm, just needs a bit of fine tuning to get it 110%
Reactions: JD1964 and liljoe07
This gave me a chuckle. Are you an engineer or other math-related type? I had a flash back to college as I read that.
Reactions: JD1964
The way I understand it to be is the 8 rib crank pulley just adds 2 ribs on the forward edge. So, the inner 6 crank pulley ribs is supposed to line up with the 6 rib blower pulley.
I'll take that as a compliment, thanks. Not an engineer but part of my income involves describing problems with mechanical, structural, electrical, etc.... in written reports.
Shipping has been slow on the new belt. Meanwhile, the current belt walked back into position on its own. So, alignment problems are less likely in my opinion. Bad belt is more likely. When I hold my finger gently on the surface of the belt with engine idling, I can feel bumps like the belt surface being inconsistent. I suppose this might be what is making the belt vibrate and randomly walk either way.
Could be the problem! Another thing is, make sure that belt is tight as a drum! If the new belt decides to walk too and is tight, there must be a slight pulley misalignment somewhere. Just a touch off can cause it to jump a rib.
Fingers crossed for Ya on the new belt!
I had a belt walking issue when I installed my current Novi kit. My belt kept walking forward 1 rib on the A/C compressor pulley. I finally figured out that my alternator was just a little misaligned. Once I got it cleared up no mo problems.
Anyway,,,,,, It's fun ain't it!?:D
Guys, i am a machinist/ millwright. I setup and maintain all sorts of mechanical rotating equipment in a refinery. We have tons of equipment that use belts and two pulleys, and yes, you use either a straightedge, or most commonly a piece of string to align the pulleys.
Two types of misalignment to look for are offset and angularity. Both can be corrected with a simple piece of string, and if you have a belt jumping you are most likely misaligned.
Here this guy shows how to use string alignment on hvac. Same principle.
View: https://m.youtube.com/watch?v=ZRz4H3PF2lE
Reactions: JD1964
Guys, i am a machinist/ millwright. I setup and maintain all sorts of mechanical rotating equipment in a refinery. We have tons of equipment that uses belts and two pulleys, and yes, you use either a straightedge, or most commonly a piece of string to align the pulleys.
First of all, my belt is plenty tight. I've tight red it twice since breaking it in. That is ruled out.
So, if a misalignment caused my belt to walk forward one grove, how would you explain that same misalignment causing the belt to eventually walk back to its correct position?
I've seen belts do lots of goofy things because of misalignment. Load it and unload it and they will jump around. The pulleys need to be on the same plane. They can be parallel but different planes and have problems (offset) or close to parallel, but one cocked a little(angularity) and do goofy things.
It's not hard to check, two people make it easier, and two minutes can rule out lots of problems.
I'd say there is a misaligent. I've had the same issue and that's all it was. Also on the backside of the belt, how much can you move it? If you are depending on just the tensioner alone then it could probably be a little tighter. I used to snug the bolts down and hit the bracket with a block of wood and a hammer then really tighten the bolts. Then finally bought this little aluminum block with a bolt through it that held the tensioner in place so it couldn't back off.
I recently had a serpentine belt alignment problem. Long story short, belt would walk a rib then shred to the point of me losing a belt completely. Turns out I needed to shim my tensioner. Double check that alignment. I also am using a professional products balancer that required a spacer for the blower pully.
