Did 5 Lug/4 Disc Swap, Brakes Are Weak
Jason 302
685
71
68
Newark, Ohio
Finally did the 5 lug/4 wheel disc swap on my car. Used the following parts....
94/95 spindles
JM Stainless brake lines up front
99-04 PBR dual piston calipers up front
Gutted and plugged stock proportioning valve
Ford Racing adjustable proportioning valve
94/95 GT Master Cylinder
Stock fox vacuum booster
StopTech "Street" Pads up front
Brand new stock 94+ GT rotors on all four corners
McClure line lock kit
Moser 31spline 5 lug rear axles
Maximum Motorsports rear brake line adapter kit
94+ GT calipers in the rear
Ceramic rear pads
Proportioning valve turned in 4 turns in from all out
So far the brakes are extremely underwhelming, takes a TON of pedal pressure in order to stop the car in a hurry, and even then it's not doing so very well. The factory brakes did a better job, if that tells you anything. Do I need to give the StopTech pads some time to seat? Is the stock brake booster way too under powered for 4 wheel disc? Should I bypass the line lock kit, it worked fine with the old setup. Really disappointed thus far with the swap (other than the looks). Some pics for reference....
Your issue is due to incorrect MC/Booster.
Your brake setup came factory (on the 99-04 V6 Mustang w/vacuum assist brakes) with the larger booster and a 1" bore MC. By sticking with the stock fox booster and going with a 1 1/16" bore MC, you've created a situation where you need a LOT more pedal effort to stop.
The 94-95 GT MC is ideal only for the 66mm single piston calipers. The 99-04 calipers have slightly less surface area so your MC needs to be a bit smaller.
Long story short:
1993 Cobra 1" bore MC
94-95, 99-04 booster or 1993 Cobra booster
Is the pedal spongy or do the brakes pump up?
Pedal feels firm about half way down
was the master cylinder properly bech bled before install?
Yes
The problem is your STOCK booster. I just replaced mine with a Cobra unit. No more sponge brakes
Thank you, I was considering that
Your brake setup came factory with the larger booster and a 1" bore MC. By sticking with the stock fox booster and going with a 1 1/16" bore MC, you've created a situation where you need a LOT more pedal effort to stop.
Long story short:
This is what I was afraid of. I knew 94/95 had single piston calipers, but I had already bought the master cylinder a few years back. I was hoping I could make it work. Looks like I need to spend some more $$$$
Thanks everyone for your replies. I'm going to order a 93 Cobra booster and M/C here next month and see where that gets me. I'll give an update and see how it works out.
BTW it's good to be back, I haven't been on here much the last several years, mustang took a back seat to motorcycle racing. All that nonsense is behind me now lol ;)
The love affair with keeping all the parts of your human body must have caught up with you again...
Reactions: 7991LXnSHO
@2000xp8 i was cool with just puttinh around but the panic stops were down right dangerous for me. I almost rear ended my buddy on his bagger and then I vowed to fix them then
sent from my butt pocket
Never got hurt too bad luckily, just a concussion one time.
That's how mine are, they don't feel too bad initially, and do the job for normal driving, but when it gets serious it gets scary.
I took the booster MC and prop valve off a 98 v6 for my rear IRS and cobra front brakes. Works well.... Way better than stock.
I ran similar brakes for years and they were just fine without the booster.
Only difference would be I used the 93 cobra MC.
I'd rank the MC more important than the booster. Some guys have big quad and can modulate the brakes well with the smaller boosters, but an MC bore reduction of 1/16" makes a huge difference in pedal feel.
If the OP was to pick one of the two changes I'd suggested only, it would be to do the MC first, and see how he likes it then. If still not enough power, then do the booster.
Ideally, I tend to recommend running as close to factory setup as possible...with a few exceptions here and there.
Curious, would you guys recommend just the 1" MC if a person was simply doing the front brakes only and leaving the drum brakes in the rear?
I think I might make a partial brake upgrade part of my project this summer, but haven't sourced rear disc components yet.
Curious, would you guys recommend just the 1" MC if a person was simply doing the front brakes only and leaving the drum brakes in the rear? .
Depends on what the front brakes are. In general though you do not want to run a MC designed for 4 wheel disk brakes with rear drums. Rear cylinders don't need much fluid to operate, so swapping in a 4wdisk MC can leave you with a hard pedal. There really isn't an ideal MC for only swapping the fronts, and leaving the stock MC is usually the best solution.
The recommendations are based on mathematical ratios of the Master cylinder piston area vs the slave cylinder (calipers) piston area. There are engineering reasons for the recommendations I've made. I don't want anyone to think I just pick them out of a hat.
Refer to
http://www.stangnet.com/mustang-for...onversion-upgrade-thread.801400/#post-8075734
I'm probably just going to do both and be done with it. I wish I had the parts when I had it all tore apart the first time, but oh well.
I'd try the cobra MC first. I did my booster last year and i'm not that young or limber. It was a major PITA laying upside down under the dash to get that damn upper left bolt and the rod off the pedal.
Ratchet wrench make it any easier?
