Build Thread Want To Blow 5 Years And $50k On A Foxbody? Step By Step Instructions Inside!
So the T56 Magnum install is underway. Now I know why they call it the Magnum. Summa bish is huge. Sitting next to the TKO-500 here.
I'm going to chronicle the install here. I didn't find a whole lot of installation details with pictures online, so hopefully my experience will help others. Aligning the bellhousing with the Magnum is a little different than other transmissions because the bellhousing doesn't have a concentric circle that can be used to dial it in. The front plate of the transmission needs to be removed and then bolted to the bellhousing without the rest of the transmission behind it. First thing is to remove the detent bolt and spring.
Once that is out, removing all the bolts on the plate will allow it to be removed. There are two pry spots on each side of the case that make removal with a screwdriver easy. Here's the plate off the trans. I already scraped off all the RTV that was sealing it to the case.
Inside of the mighty Magnum.
I then bolted up the bellhousing with just the flywheel installed. You can see why it's not possible to index this bellhousing without the front plate.
I put the front plate in place and noticed it was crooked. After talking to some people, I'm told this is normal and that transmissions typically favor the driver. I had to stop at this point anyway because my dial indicator base is too thick and wont let me install the plate because the input shaft sleeve sits too close to the flywheel.
Speaking of the input shaft sleeve, there is a lot of information on the internet that the sleeve needs to be shortened when using a twin disc clutch.
After some measuring, I only have 1/8" clearance to the sleeve once both clutch discs are installed. I'm going to shorten the sleeve the 0.20" that I have seen recommended online.
The webbing of the front plate also needs to be trimmed back thanks to the extra space that the twin disc takes up. The clutch fork hits the plate in certain areas. The green spots are marked up for my machine shop. I'm going to have him shorten the sleeve and machine down those spots at the same time.
Once the sleeve is machined, my dial indicator base will actually fit so I can get back to aligning the bellhousing.
I could just bolt this thing in and call it a day (minus the mods for the twin disc) but I don't trust everything being aligned the way it should be. With my luck, the bellhousing will be the smallest bit out of alignment and will cause tough shifting or clutch engagement issues. I'll feel better knowing everything is parallel and concentric.
i think this is more of a (perceived) problem with tko's than any other transmission just because they tend to shift so poorly that people will blame anything for it. the real problem with them is the heavy gears, brass syncros with too fine of teeth, and a what seems to me to be a binding shift rail/lug (at least on mine).
did you get a whole kit from somewhere, or are you piecing this swap together? i was eyeballing the dnd kit, but looking at the pics the crossmember they sell doesn't impress me all that much. i'm a long way from a purchase anyway (just paid $2600 in real estate and $800 in personal property taxes, so gotta let the bank accounts rebuild again) but it never hurts to research.
btw, your pics are almost epically clean, and look about 1000x better than the ones i keep seeing in the online mag's.
Reactions: RacEoHolic330
You could be right about that. Maybe it's the mods that were done to my trans, but I've never had any shifting issues with it. Sure, it's a little notchy, but definitely not something that bothers me. I have a stock shifter handle on it too, so that helps.
I'm pricing everything together. I found the trans second hand for a few hundred dollars less than buying it directly from D&D. I also wasn't a fan of their crossmember, and I needed a beefier driveshaft. I went with 1350 u joints and a chromoly slip yoke. A local guy sold me his nearly new PST driveshaft for $150. I just need to have it shortened. I'll come out ahead compared to buying the complete kit. Not by much, but it will have exactly what I need.
Glad you like the pictures. Photography is a (very) small hobby of mine. Although I don't do anything to try to make the photos of parts look extraordinary, I try to take the time to get a halfway decent picture. Shooting in full manual mode and having an external flash really help. The good quality pictures have come in handy when I'm referring back to something I did years ago.
Reactions: stangboy
Hey man your car is amazing!! I just finished reading all of this thread and thank you for sharing all the information and pictures of your awesome build, by far the best thread I have came across. You have definitely motivated me with my car again and gave me lots of ideas. Looking forward to more progress of your car.
Glad I can be an inspiration to you. Other builds on this forum have really inspired me in the past as well. They give me the kick in the ass I need to get in the garage and start working.
Don't praise him to much.. Been like four years and I've still not seen one burnout video....... Lol
:D
:burnout:
Burnouts are whatever . It's when you're doing 50-60 and it breaks them loose now that's interesting .
Been a long time since ive been on this forum. Came across your Instagram and Car now that im looking for a new foxbody. Car is great. Your attention to detail is next to none. Lots of inspiration in this thread.
Thank you! Glad you like it
:D
:burnout:
This is as close as you'll ever get to seeing a burnout from me, unless you're the one buying me tires!
View: https://youtu.be/0KpvjHmACKA
Man, i am the exact same way. I used to love frying those suckers, but today's tires are so high i cringe when i get it a little loose these days..:rlaugh:
I don't mind spinning the tires while accelerating, to include blazing the snot out of them while they attempt to propel the car forward. ( I'm not thinking that'll be my issue anymore) What I just cant do anymore is stand on the brake at the same time. If you ever come back to the scene of the crime after a nasty dry burn out and look at how much rubber is piled up and sprayed all over the place, you cant help but think,.."How much did that little stunt cost me?" Especially mitigating in Scott's case when the tires are like 400.00.....................each.
Exactly. The nittos on mine weren't quite 400 ea, but yeah. I need to go get some cheapos i can bolt on just to go play on. Lol.
