Electrical Eec Capacitor Replacement, Pin 46 Jumper To Ground, & General Eec Work Question
DuderMcMerican
148
9
28
Woodbridge, VA
Hey gang,
I have no continuity between pins 46 & 40/60 on eec connector, so I pulled the eec to inspect. After inspecting both sides of the circuit board, I saw no obviously fried circuit to go ahead and jumper (as has been the case for others). The only obvious issue was a leaking capacitor, so i will replace it along with the other two while I'm at it.
Could the bad capacitor be the culprit for my pin 46 issue? I will test after replacing caps, but if issue persists, how should I go about identifying where the issue actually lies? Can I simply jumper post 46 to post 60 where they lead into the eec, that is, the posts that connect pins to circuit board?
The only other issue I saw is that one edge of the circuit board appears a bit oxidized (rust colored)? Is this a problem? Something I should try to clean up?
Finally, I noticed that the circuit board is covered with an insulating film, which I assume would have to be removed in the case of adding surface jumpers. Is that something that needs to be replaced afterwards, and if so, do I need a special product, or will a general waterproof epoxy spray/adhesive/clear plastidip do the trick?
Thanks!
I used a bit of alcohol to clean mine befor soldering. And then coated it with nothing. I believe the colored stuff your talking about is the coating they use. It's kind of tacky feeling too right?
Here is mine.
Pin 46 is a signal return. You won't get continuity. First check your harness at the pin 46 side on your eec connector to any sig return on the map, tps or diagnostic plug. If there is no resistance and all is good your harness is good.
Next plug the comp back in and check again at tps, map or diag. Plug. If you has resistance your trace is likely bad. It's very hard to see so use a magnifying glass and good light.
Here is my bad one before the fix. You can barely see the burnt trace.
You see the 3 little brown things going up and down. It's the dark spot between the bottom one and the second of 3. Hope this makes sense.
I don't really know what the caps are for but definitely replace all if your in there. When I looked for caps I found you had to buy a minimum order of 100. Coarse it was only a few bucks. I have another a9l with 2 bad caps I need to fix someday.
Thanks for your reply! I found two of the caps at Radio Sh** and ordered the other one on Amazon for a few $. Prob should have just ordered em bulk..
I do see the burnt trace between brown things 1 & 2 (official tech terminology.. Haha). I'll have to take a close look at my board this evening..
I did check the resistance between pin 46 and those terminals/sensors you mentio. (per jrichker's checklist), but i thought that I read that pin 46 is grounded within the eec and that it's pin terminal should have continuity with 40's and 60's pin terminals, no?
Yes, the tacky rubbery film with a greenish tinge is what i was referring to, but i also mentioned that one edge of the board had an oxidized rusty look to it (just on the very edge, profile view, not on the board surface itself). Any experience with this? Is it something of concern?
I thought the same thing about continuity between 40 and 60 and the SR. But it's not the case. What was your reading checking the harness?
I really don't think the edge being a discolor will affect anything. As long as it's just the board and not into any traces.
Your on the same track I'd be on, replace caps, check closely for a burnt trace and plug it in and see what happens.
Pin 46 signal ground connect to pin 40 and 60 inside the computer . You should see less than 1 ohm between pins 40, 46 and 60.
Signal ground eliminates the voltage drop problem common with using the power ground as a return path for voltage critical circuits like sensors. Anytime you draw current through a wire there is a voltage drop. The more current the wire carries, the greater the voltage drop. Use a dedicated signal ground for sensors; they draw only microamps of current, The voltage drop on a 16 or 18 gauge wire signal ground wire will be so small that it does not influence the accuracy of the sensor readings.
Notice that there are 3 ratings on a electrolytic capacitors, one for voltage (higher is OK) one for temp (higher is OK) and the last one for capacitance in MFD (match this one as closely as possible) .The tolerance for MFD is typically +/- 20%.
Try www.digikey.com for any kind of electronic part - much cheaper than Radio Shack and the quality is much higher.
Reactions: DuderMcMerican
I haven even corrected. I saw no continuity thru mine as my trace was bad. I never checked it again after the repair. Sorry for the miss lead....
No prob, Bob. Welp, i reexamined the pcb when i got home, and it looks like the burnt trace between brown things 1&2 may be the culprit. It isn't obvious but it's there. Thanks for posting that pic!:flag:
I won't be messing with it for a bit because i went ahead and ordered better capacitors from the site jrichker suggested. I'll be sure to post an update, though, after I do the work..
Thread update:
I got the digikey capacitors installed, and I jumpered the burnt trace (pics attached).
The jumper works as pin 46 now has continuity with 40 & 60. Thanks for the replies, jrichker and bob :nice:
One concern I have is that one of the 46uf caps is showing 0 resistance on analog multimeter. My understanding is that on-board cap tests with multimeter are all but useless EXCEPT when cap reads 0 ohms (needle pegs and doesn't regress back) or infinite resistance (needle does nuttin). In my case--0 ohms--the online says it's a shorted (bad) cap. Well, i pulled one pin out of the board and tested resistance again, and the meter read exactly how it should (needle pops to no resistance but quickly regresses back to greater resistance)..
I went on yahoo to google the meaning of these results (thinkin maybe there's a short elsewhere on the board??), but all i found is that ppl says it's a bad cap.. But it's a brand new Japanese cap that tests fine when disconnected feim board, so I'm thinkin it's prob not the cap, but idk.. I'm hoping I can just chalk it up to "cap tests with ohm meters aren't reliable when cap is in circuit..." and not worry about it, but other info suggests 0 ohms--even when in circuit on board--is trouble. Anyone have thoughts on this?
Btw, the analog multimeter i use has max ohm setting of only x1k, in case that matters, but i did also try my cheapo digi meter with max 2000k ohms and it still read <1ohms with no regression..
It seems that the jumper did the trick as I was able to dump codes again!:poo:
However, I'm now experiencing new issues. :dammit: It seems that I'm NOT getting code 11 except when it spits out the continuous memory (CM) codes. In fact, that's the only CM code I'm getting..What's that mean? Just that my EEC remembers being fully functional at one time in the past? I did used to get code 11s.
Thanks to jrichker's "dump codes" tutorial, I know that no code 11 means there's something (still) wrong with the EEC or it's wiring, but does that mean that the codes I DID get are unreliable/meaningless (KOEO 21, 22, & 24, and KOER 21, 41)?
I also got a cylinder balance (CB) result of 80 (doh!), but I always got 90 before. I did notice that the car didn't behave quite as it used to when I ran CB test... the switching from one cylinder to the next was not perceptible as it was before.
BTW, I did delete old codes by pulling the jumper after the KOEO first began. Then I went back and ran the tests that yielded the above results. (And I did have AC off and clutch depressed:D)
Codes are still valid even if your didn't get an 11.
Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
Note that that if the outside air temp is below 50 degrees F that the test for the ECT can be in error. Warm the engine up until you get good hot air from the heater and then dump the codes again.
The computer Engine Coolant Temperature sensor has absolutely nothing to do with the temperature gauge. They are different animals. The ECT sensor is normally located it the passenger side front of the engine in the water feed tubes for the heater. It has two wires that connect by a weathertight plastic connector.
The water temperature sender for the temp gauge is located in the driver's side lower intake manifold. It has a single wire that connects by a push on connector on the temp sender.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate readings.
Pin 7 on the computer - ECT signal in. At 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. At 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer.
Voltages may be measured across the ECT/ACT by probing the connector from the rear. A pair of safety pins may be helpful in doing this. Use care in doing it so that you don't damage the wiring or connector.
Here's the table :
50 degrees F = 3.52 v
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
212 degrees F = .47 v
230 degrees F = .36 v
248 degrees F = .28 v
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
212 degrees F = 2.07 K ohms
230 degrees F = 1.55 K ohms
248 degrees F = 1.18 k ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
MAP/BARO sensor operation and code 22
Revised 14-Nov-2014 to add wire colors for frequency & voltage testing and engine sensor wiring diagrams.
On a Speed Density car, the MAP/BARO sensor is connected to the intake manifold and acts to sense the manifold pressure. Lower vacuum inside the intake manifold when combined with more throttle opening measured by the TPS means more airflow through the engine. As airflow increases, fuel flow through the injectors needs to increase to keep the air/fuel ratio where it needs to be. When manifold vacuum increases, the engine is either decelerating or idling, and it needs to reduce the fuel flow through the injectors.
On a Mass Air car, the MAP/BARO sensor vents to open air and actually senses the barometric pressure due to changes in weather and altitude. Its purpose is to set a baseline for the computer to know the barometric pressure. As barometric pressure decreases, it leans out the fuel flow to compensate for less oxygen in the air. When the barometric pressure rises, it increases to add fuel since there is more oxygen in the air. The fuel requirements decrease as altitude increases, since the atmospheric pressure decreases.
Disconnecting the MAP or BARO sensor will set code 22.
Misconnecting the BARO sensor to vacuum on a Mass Air car will cause the computer to lean out the fuel mixture.
Code 22 or 126 MAP (vacuum) or BARO signal out of range. The MAP or BARO sensor is pretty much the same sensor for both Mass Air & Speed Density cars. The main difference is where it is connected. Mass Air cars vent it to the atmosphere, while Speed Density cars connect it to the intake manifold vacuum. Its purpose is to help set a baseline for the air/fuel mixture by sensing changes in barometric pressure. The MAP or BAP sensor puts out a 5 volt square wave that changes frequency with variations in atmospheric pressure. The base is 154 HZ at 29.92" of mercury - dry sunny day at sea level, about 68-72 degrees. You need an oscilloscope or frequency meter to measure it. There a very few DVM’s with a price tag under $40 that will measure frequency, but there are some out there.
Map sensor wiring:
black/white - ground
orange/white or +5 volts power
white/red signal out.
Measure the +5 volt supply using the orange/white and black/white wires
Measure the signal using the black/white and white/red wires.
The MAP/BARO sensor is mounted on the firewall behind the upper manifold on 86-93 Mustangs.
Baro or MAP test using a real frequency meter - run the test key on, engine off. The noise from the ignition system will likely upset the frequency meter. I used a 10 x oscilloscope probe connected from the frequency meter to the MAP/BAP to reduce the jitter in the meter's readout. And oscilloscope is very useful if you have access to one or know of someone who does. With an oscilloscope, you can see the waveform and amplitude.
If it is defective, your air/fuel ratio will be off and the car’s performance & emissions will suffer
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cable. It should be less than 1.5 ohm.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
a9x-series-computer-connector-wire-side-view-gif.71316
eec-iv-computer-connector-for-5-0-mustang-gif.88243
Diagrams courtesy of Tmoss & Stang&2birds
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Code 24 - Intake Air Temperature (ACT) sensor out of range.
Bad sensor, bad wiring. The ACT for Mustangs built before 95 is in the
#5 intake runner. It measures the air temperature in the intake to help
computer the proper air/fuel ratio.
Note that that if the outside air temp is below 50 degrees F that the test for the ACT can be in error. Warm the engine up to operating temperature and retest.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts.
Here's the table :
194 degrees F = .61
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 11-Jan-2015 to add check for fuel pressure out of range
Code 41 is the passenger side sensor, as viewed from the driver's seat.
Code 91 is the driver side sensor, as viewed from the driver's seat.
Code 172 is the passenger side sensor as viewed from the driver's seat.
Code 176 is the driver side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (L\RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Check the fuel pressure – the fuel pressure is 37-41 PSI with the vacuum disconnected and the engine idling. Fuel pressure out of range can cause the 41 & 91 codes together. It will not cause a single code, only both codes together.
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
Code 80 with engine running - cylinder #8 is weak or dead.
See
View: https://www.youtube.com/watch?v=HDXrkKS4jTE
for a visual tour through the process. There is no voice narration so you have to listen carefully for the engine sounds.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
Hey gang,
Thanks!
How did I get it solder on mine won’t stick
The PC board is often coated with a sealer/resin that you need to dissolve the get solder to stick. Acetone and a small bristle brush are the best tools to clean the board prior to soldering. Prior to soldering, clean the solder area with Isopropyl alcohol (rubbing alcohol).
If you don't have good experience with replacing components on PC boards, a TV or electronic repair shop might be the best choice to have the capacitors replaced.
See
View: https://www.youtube.com/watch?v=AqvHogekDI4&t=167s
