New Belt Tensioner Issue
Aaron
Dec 5, 2003
95
40
38
Buffalo, NY
So it was finally time to replace the factory belt tensioner on my '87 GT, as the bearing was squeaking on a regular basis. The old Ford tensioner was great in that it has a lip on both sides, and a bunch of grooves inside to help keep the belt in place.
La7LyYcwFSeL-ojDADIFaFiZS1sUzXLhdBDWpBVsWr09S7T0lVsMUSTbibhDQmXUQhpB0rH_ocwHKhLawhM=w325-h577...webp
Well the new pulley is 100% smooth, no guides, no ridges, etc.
G4If-LQIgX-56QIkSlc1ueiC174dk5Km_uOqO2FNo7NgzBcrC_n5K69EpxEo4M-g9w_cPEEcBVZP7qV78hg=w500-h410...webp
My first thought was "how is the belt going to stay on this thing? Sure enough, after installing it and running the car for only short period of time, the belt tracks to the point where it's halfway off the pulley.
0Y41YRx9YSmeS2kULyYinD4ffsuMheZR_xdSMM3-zpzieKQjz6ahNCepOkyA5ueNFe8vIl1Scjm6hthxAmY=w325-h577...webp
7qTajqBonUTMaWUYkFdlISL7iohuaWpmU-tJUc74xplSCGGB96XZrLwnfT9ECkbehXn6j3oo6FanvyVOqio=w325-h577...webp
Even if it does stay on, we're talking premature belt wear for sure. I got the tensioner from Latemodel Restoration. It's 100% metal, so it's not some cheap piece of junk, or at least I thought it wasn't going to be junk. Any ideas?
That is not the correct tensioner for your car.
Any pulley that is facing the belt will be grooved. That should have tipped you off immediately.
Return it, get the right one with the correct pulley.
Reactions: Aaron
Hmmm...problem is just about everyone looks to be selling similar units, amd not just LMR. What the heck...
That does not look like the stock tensioner location. It is on the alternator bracket on the passenger side. What is the year engine size and model, any modifications that you know about?
It's a standard 1987 302 engine, with AC removed. I bought the car roughly 15 years ago with the compressor already removed, and always wondered how the AC would have mounted with the tensioner where it's at.
:Edit: I just looked at a bunch of engine bays and sure enough, the tensioner is attached to the alternator bracket. Never realized it. Well this sure throws a wrench into things.
I'll have to take another look tomorrow and see if I can move the tensioner to it's correct spot.
That's what you get when you order a replacement tensioner for these cars. Whether it's ford, or aftermarket....it's the same.
Reactions: Aaron
That is what it looks like. Wish they still made the grooved style ones, but as long as it works, so be it.
So it only took me 15ish years to realize whoever removed the AC compressor must have figured out that they would not have to replace the belt to the shorter version if they moved the belt tensioner into the old AC compressor spot. Here's a pic of the engine bay. Yeah I know it needs cleaning :(
Q6bhWX6psghyMB5pAyGeMaa7k4Gsl7ahLv0Nnj60wXINnSvL8jEtJWRM7QFHu4Mf5hw74q6iHHkeje-fGE=w1026-h577...webp
Looks like the screw hole and alignment hole are still on the alternator bracket, so after work, I'll have to run out, get a new shorter belt, and move the tensioner over to where it's supposed to be.
Thank you a91what for realizing what the issue was!
Once he gets the pulley in the right spot, he's not going to have this problem anymore. His belt is coming off the pulley because of an alignment issue. Once he gets the assembly back in the stock location and things are squared up again, this will be a nonissue.
I've had my replacement tensioner on there for two years now and have never had a problem.
Reactions: Aaron
I have the same set up on mine, you cant move the tensioner back to the stock location, it may cause the belt to rub on itself and if not it will put too much tension on the power steering pump and eventually break the bracket holding it. Trust me I know from experience haha, whoever owned the car before you knew that and put that ribbed pulley on it and relocated it with probably the trick flow or march a/c delete kit. Just go to your local auto parts store they will have a variety of different pulleys find one thats 6 ribbed and the same diameter as your old one and you will be good to go
Reactions: Aaron
The assembly I just pulled off looks to be the original Ford setup, so I don't think the ribbed pulley is aftermarket. Lets hope LMR isn't a pain with returns. If all I can go with is a new pulley, there is no point in keeping the entire new tensioner.
The ribbed pulley is aftermarket trust me that triangle shaped bracket the tensioner mounts too is also aftermarket
Or just move the tensioner to the right location and get the actual delete pulley....
iirc...... won't having a ribbed pulley on the stock tensioner cause the bolt to want to back it's self out... I understand it's on a bearing race but I would definitely check first to see if the "original" was threaded the opposite way.
I have the exact same set up on mine dont put the tensioner back to the stock location you will give yourself nothing but problems just buy another ribbed pulley every auto part store sells them
Yes the stock bolt is reverse threaded tighten it down as much as much as ya want and throw some thread locker on it just like it came from the factory, I'm not saying putting a delete pulley on is a bad idea I just think its unnessisary because the tensioner relocater you have works just fine
So here is a better pic of the old tensioner assembly. Tensioner itself is Ford, and pulley could be aftermarket I guess:
Q1Pb8lccX0rk2OAtfjXR6xT3qN93cXMF_i5v1kzLcKXh2tUKy6XZNMuUt0JLKuh5MyOEjjR6LwnZ74ZRPw=w1161-h653...webp
Since the tensioner itself is good, I'll head out to Advanced auto or Autozone later on today and see if they have a pulley that matches what is on this today.
Ill show you a pic of mine if you want to ease your doubt stock tensioner pulleys on these cars are flat just like the one you bought because the stock location makes the tensioner push on te rear of the belt where it is not ribbed you can see that for yourself if you look how the tensioner mounts to the alternator bracket
Reactions: Aaron
So I went to Advanced Auto and Autozone and came up empty. Nobody has a ribbed tensioner pulley. I know Foxbody95 said not to move the tensioner into it's original spot, but I wonder if this is not a bad idea, given I am having trouble finding a proper pulley. Here's the belt routing diagram off of my car for both with and without AC. As you can see, the tensioner is in the same spot for both applications.
1s7IInBEEp0Bf0v6MrpF9GACSFAnK7w9KU3AXdBwtz7v2liIVoBse0wIIjf4JumEi3btn34OtM_lFQ0kzCQ=w368-h653...webp
Why wouldn't buying a shorter belt meant for non AC cars work here?
Wow man, that is crazy. I'm SURE that took some work!
Anyway, that Dayco pulley looks exactly like mine, and funny thing is that the Advance Auto Parts store I went to earlier has it in stock. Guess that is where I am headed.
Everyone, thanks for the help! Looks like I'll be all set tomorrow.
