1993 Radiators Rebuildable?
All Stock93
5 Year Member
Apr 16, 2016
349
542
123
hi all,
I am searching for a stock 93 Radiator to replace the aftermarket aluminum radiator my car currently has. I was wondering, since I don't have a factory radiator to look at, if they are able to be rebuilt or are they plastic throw away's?
Also, is there any difference between 5 speed and auto cars or are the units the same?
Thanks
First why would you want a stock one? Aluminum is way better for heat dissipation.
Second: The oem radiator isn't worth rebuilding. Its not cost effective when there are tons of aftermarket oem style replacements. I bought one at Advance Auto last time I needed one. Quality was good fit was good. Price was reasonable.
Thanks,
I want a stock one because that's what belongs in the car. This car gets used on sunny days only. Never raced, all original as Ford built it. Extra cooling isn't a priority, 100% original is. I just want to make sure it isn't plastic before I buy one
The cost to rebuild/recore a copper/brass radiator is easily equal to the cost of a new aluminum HD 2 core from Rock Auto parts.
Unless you are doing a restore to original condition rebuild, the rock auto radiator is the way to go. P/N is OSC 138 - Heavy Duty 2 core aluminum, equal to 3 core. All aluminum, welded tanks,
See http://www.rockauto.com/en/moreinfo.php?pk=3757926&cc=1134076&jsn=460 cost is $106 + shipping.
Reactions: General karthief
Guys, Thanks for the help but I don't need an aftermarket unit. I already have a perfect aluminum radiator that is only 2 years old but I'm working towards MCA unrestored class shows. I need a correct FOMOCO radiator from 1993
I have found two suitable radiators but I want to make sure they can be rebuilt if necessary. I know most manufacturers are using plastic tanks these days but I was under the impression that they are throw away units that cant be rebuilt due to the plastic tanks.
Also still wondering if 5 speed and auto use the same unit or if I need to find a 5 speed specific unit
Thanks again
AOD units will have the provision for the trans cooler in the driver's side tank on the radiator. Do not know if the 5-spd units had this.
As for rebuilding them, not sure. Been some time since I've seen a stock fox radiator. I want to say they are NOT plasti tanks on the sides though.
Reactions: All Stock93
My stock radiator had plastic side tanks.
My stock radiator was brass and copper. It was rebuildable and my radiator did have an internal trans cooler. The car was a 5 speed. The radiator was thicker than the replacement aftermarket one. I do know for a fact that 89 was rebuildable...not so sure about 93.
Have you checked over on 4eyedpride forum ?...there are a lot of purists over there.
I think what you're doing is pretty cool. Nothing wrong with an all stock 93 fox. Really won't be a n y t h i n g wrong with its value in another 10 - 20 year either.
I'll research the great interweb and report back if I find any new info for you.
Thanks for the help guys. I appreciate any info.
My stock radiator was brass and copper. It was the uikdable and my radiator did have an internal trans cooler. The car was a 5 speed. The radiator was thicker than the replacement aftermarket one. I do know for a fact that 89 was rebuildable...not so sure about 93.
I think what you're doing is pretty cool. Nothing wrong with an all stock 93 fox. Really won't be a n y t h I n g wrong with its value in another 10 - 20 year either.
Thanks for researching this. I have a call in to the local radiator shop so I will also check back when I have info
I should be pulling the stock radiator out of my 93 convertible in a few weeks, nothing wrong with it I'm just doing an engine swap so it'll have to come out anyways, I'd be interested in possibly swapping radiators with you.
I'm watching an ebay auction right now, ends in 5 days. If I don't win I may be good with that offer, thanks
Reactions: krazedstang
I'd like to see some before and after pics of the radiator when its rebuilt. Would be nice to find out if there were any stamping marks or paint marks on them and if they could be duplicated.
