Upgrading Throttle Body?
Mustang936590
35
So I'm looking to upgrade my TB and have a few questions. Right now I have the stock TB with a typhoon intake and 24lb injectors and I'm debating if I should go 65mm or 70mm? And how are the SVE throttle body and spacer kits that LMR sells? They're so much cheaper than the other brands but that just makes me more nervous about quality.
I love LMR as a company but I tend to stay away from the SVE stuff. It's mainly Chinese copies of other companies stuff. An Accufab or BBK would be better, and the 65mm should be plenty for your setup.
I was tempted to go with the cheaper ones, but in the end I went with the Accufab 75mm, yes it's a little larger than I needed but what the hell. Works great with zero problems and no whistling.
The only thing I can add here is if you buy the bbk tb and you get a whistle, don't assume you have a vacuum leak, I chased that whistle for a couple years and actually found out here that it was the tb.
The whistle is loud enought to scare ricers at stop lights. :banana:
Very little to gain at this point with a TB swap if you have stock heads/cam. If you are going to go with a 65mm TB, I'd just pick up an Explorer 65mm TB and modify it to work on the Mustang. Cheap, and you get an OE quality TB since it is OEM.
Beyond 65mm, I'd go Accufab, but they are expensive. Given the minimal gain you'll gain at your level of modification, I feel that $$$ could go to something else.
A lot of complaints about BBK Throttle bodies making a interment whistle noise.Mine a
(70mm) comes & goes.Tried everything to no avail.Some claim its the way the internal castings are done.
If you get lucky it will whistle at a red light.With a hot chick crossing the road :):):)
So how do you get rid of the whistle? I have a 70mm BBK and it never whistled till I removed the egr valve and blanked off the holes.
