Progress is good. These are some of the reasons I will never do long tubes. They're not worth the headache.
If you're comparing going from a stock 5.0 to long tubes, sure you'll see a big difference. You'd see a big difference going to mid-length as well.They were definitely worth it on my Fox, idk about mod motors. I really want a set for my 03 and my 12. I'd have to be the one to install them though.![]()
Ask them to check out the hoses to the core as well. Once upon a time, I blew up a heater core and found my hoses to be thin in places as well. It would be a bummer to swap the core then blow a hose or to clog up your new core with deteriorating hoses.Got under the car to find good news for once. It was just the dipstick tube on the trans leaking. Some taps with a brass hammer and its in place and good. Cleaned up a few other small things and dropped it off for a new heater core.
Oops!The hoses are new as well. We bent the heater core tube just a tad when installing the motor the first time. The core was leaking right at that crease. Doh.
The transmission is still puking fluid. I'm going to drop the pan today and replace the gasket. That's the only item left aside from a hairline crack the opens when the trans is hot and leaks.
There isn't enough difference between shorties and long tubes to be worth the headache *for me*. I'd rather spend my time and money elsewhere versus putting on a set of headers that is going to make life miserable under the hood.
I think I got the pan lined out. New gasket. Twice. I stripped a bolt hole and had to drop it back out again to heli coil a thread hole. That sucked. But it's fine. Pan seams to have sealed so far but it seems to get worse and leak over night.
One issue solved and three more arrive.
The o2 that you have to remove to drop the pan has shorted out against the pan. I cut it off and plugged that hole. I'm trying to find someone to weld in a new bung in my garage so I don't have to trailer it to an exhaust shop just for a damn sensor.
The pos saga continues.
I believe I'm going to have it tuned then sell it. I'm tired of working on it all the time and don't want to keep doing this anymore. This car has made me royally hate this hobby.
Felt like that more than once, good luck.
ton of fluid on the floor and was getting on the header (smoking like a champ).
TON in machinist terms for flatness. No freaking wonder I couldn't get the damn thing to seal.Well it was too good To be true. I can see trans fluid on the ground. Again.
