Hello everyone,
I am new here and am looking to solve an issue that I have come across. A little back story to start. I have a 1999 4.6 2v motor and trans that I pulled from the car and have transplanted into the shell of a 2003 GT car that was originally a standard.
The swap went well, quite straightforward. I have hooked everything up electrically, grounds etc. I have swapped the cluster, ignition switch, lock cylinder, pats module, and PCM as well. When I hook up the battery, I have power to everything it seems, the cooling fan turns on, I can hear everything under the hood getting power, but when I turn the key I get NO CRANK NO START.
When I get under the car and jump the terminals on the starter, the starter kicks, but the motor still doesn't crank.
I am at a loss here, anything that can get me going in the right direction would be awesome!
