Ok sounds right, 3 wire will be a hall effect sensor. Needs 12v or 5v input gnd and signal out to vr2. Looks like your good to go, if you have troubles with cam sync we will need to add a pot resistor to r39 and tune it in.That’s what bugs me about MS. There’s so much info out there that all says different things. The manual says use VR+/- and ground (3 wire). The guy that sold me the cam sync says use VREF and SGD for my +/- leads. I find info that supports both. So maybe it doesn’t matter?!
For what it’s worth, I’ve got the cam sync going to VREF and SGD, signal to VR2
I’ll give it all a try. If it starts on the first go, I’m buying a Lotto ticket
