Header Bolts....i'm Scared...
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
OK, So that 94 Cobra...you know, the one I am leaving stock...ummm...sorta, well not really,,,aaaaanyway, I want to put on a set of headers. The original headers are still on the car..yeah, the ones from 1994. I am worried about those bolts coming out nicely. The last thing I want is to snap a header bolt taking them off. Any suggestions? Advice? Just go for it...?
Prep them with PB blaster for a few days leading up to it, assuming you aren't driving it every day. And I have always had good luck using a propane torch to heat and loosen bolts.
Joe
i wouldnt waste my money on locking header bolts.
12pt bolts from mcmaster with a dab of RTV on the threads and you'll be set. prob only run you like 20 bucks all said and done and be a lot easier to deal with
Plus the $40 in shipping to Hawaii.
As others have said, penetrating oil (#MeToo) and some heat.
Reactions: Mstng93SSP
I'm not going to watch the video, please tell me what happens, I take it you disagree?
I'm not critical, just curious
From the video: RTV sealant can build pressure when curing inside a blind threaded hole which can damage the casting or weaken the threads. He recommends to only use anaerobic sealant.
Have to say, those "plastic" discs they are using clean the gasket material off the aluminum case sure look like 50 Grit 3M Roloc Bristle discs. Not sure I would use one of those on aluminum, definitely not on an aluminum head or any critical sealing surface for that matter.
