Fox Does this look normal? Also what are these 2 connections?
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
First question. Does the placement of the steering wheel look fine? I can't get the column cover over it
Second what are these two connections for? I have a 93 lx coupe
Is it me guys or does that steering wheel look like a newer one, like SN95? I have an 88 and don’t remember with the side of the airbag steering wheels look like. @James V, we’re the covers always there? Upload a pic of the front of the wheel. Something looks off.
Then your column is correct, the instrument housing is wrong.
this is a common occurrence, a 4cyl to v8 swap is a daunting job and most are not done correctly resulting in flipping the project to pass the headache on to someone else. Do you know what what harnesses were used?
The harness hanging in the second picture is the shift lock actuator and here's a pic of the steering column trim out of a 93. You have the 90-93 steering wheel, and cluster surround so I would think the column trim would fit.
car.
If your gauge cluster is flat across the bottom it is the wrong one. The 87-89 are flat on the bottom. The 90-93 are rounded due to the airbag steering wheel. I bet yours is flat and that's what is causing this issue. Other than the bottom the clusters look the same. The top picture is an 87-89 cluster. The bottom is a 90-93.
