Progress Thread 96pushrods 347 build - Dyno results in!!
96pushrod
I think they're a little easier to get off
5 Year Member
May 15, 2018
1,530
871
133
Savannah
Hey all,
I’m beginning my car build today. Got a 347 from fordstrokers, big shout out to Woody and Nicole. I wouldn’t want to go through anybody else.
Car is a 96 v6 model that has been set up for a 302.
Car will have an Astro a5, which I have already picked up.
Engine is a dart block, trickflow 205 11r, Callie’s crank, scat h beams, wiseco pistons. Built to handle some good power.
I’ll be updating as often as I can.
Edit:: Cars almost done.
View: https://youtu.be/EkDJGlp3DTs
You are starting off with a what should be a bulletproof long-block.
any plans for a power adder later on?
I’ll be adding a nitrous kit along the road, my buddy fabs custom turbo piping so that’s also an option. With 10.8:1 compression I’m probably just gonna run it with a 150 shot for a bit.
Only worked for a couple hours today. Got all the harness and what not disconnected along with other miscellaneous crap and ac lines.
Engine will be coming out next Monday as I work during weekends.
Man, Im jealous of that engine. I also have a Woody 347 that I bought used, but it only has baby Trickflow 170's on it and a stock block. I'll be following your build, I like SN's.
Thanks man, I’m definitely loving the engine so far. I glad I do after all I’ve put into it as far as the block and all the supporting parts. I had matt moss port the lower intake as well. Pretty much no expense was spared on the build.
We’ll see what it puts down. The cam seems a little on the small side for what I’m going for, but the dyno will tell me everything I need to know.
Reactions: 95BlueStallion
Lol I run just about the same cam in my 302.
57x lift 224 236 @50 114lsa
Custom cam for my m112 5.0 blower build... Idles like a stock cam sounds good power everywhere.
Gonna seem small in a 347 methinks.
Yeah I was thinking the same thing. I was at least thinking the Duration would be a bit longer, maybe a hair bit more lift as well.
Oh well, I’m sure it will run and idle well. It will be good to have a cam that plays nice while I get the engine initially fired and broke in
The rubber mounts still held good, I have a tough time justifying not replacing them when I'm in the area though lol. I'm going with poly mounts everywhere this time around. I figure with a little more twist it would be beneficial to stiffen things up a bit.
Was one of the smoother pulls I've done. The only thing that gave me grief was one of the PS pump bolts. I had to grind one of those suckers off. Definitely going with ample amounts of anti seize this time around.
That and the Georgia heat can be a bitch.
RIP old exhaust. Anybody need an x pipe? Haha
Thank you. Not bad for just me working on it.
It’s fairly common on dart blocks to have to do a little massaging around the mounts. They’re pretty beefy.
I wanted my accessory brackets, coolant tubes and water neck to match the valve covers and upper intake. Hit them with some black wrinkle. You’ll notice I also lopped off the smog pump mounts. No need for that extra :poo: :D
Got the torque box reinforcements in today as well as the fuel pump. I think I set a record for quickest fuel pump install lol. Got pics of the torque box plates. I did uppers and lowers. Figured y’all know what a fuel pump looks like so I didn’t bother with pics of it.
All I’ve got to do is a wideband, then just waiting on intake and headers to finish the build.
