I purchased a complete engine for a local classified site that had sat outside for a few years, it's out of a early 90's Mustang GT so perfect for my 87 GT, the block is at the machine shop and will be ready to picked up Monday as a short block 306 (had to bore 30 thousands over do to rust in #1 cylinder) with an E303 cam.
The problem is the crank pulley was buggered up and the distributor is badly corroded inside so need to replace them both unfortunately 5.0 foxbody Mustang"s are in short supply in the junkyards around here but trucks, vans, and large sedans are plentiful so before I head out on a junkyard run today I was hoping to see if any of you my know if there's other more common (to my area) vehicle that I can use the crank pulley and distributor off of?
