- Jul 7, 2005
- 1,563
- 1,110
- 164
Amazon, picked the better looking one that were rated well. Going to do my own pin check before installing.Where did you buy the pigtails?
Would be great if you could keep us updated on how you make out with the pigtails and what/how it needed to be repined.Amazon, picked the better looking one that were rated well. Going to do my own pin check before installing.
No problem, I wish i could have gotten away with just changing the connectors to ev6 by crimping on new terminals and building each connector. Some of my injectors need the extra length in the harness so splicing on a pre-made pigtail made the most sense.
I have no idea how many pins need to be moved on the extension harness yet so i will try and document that as well as i can for you.
It does,...I wish I woulda bought that one instead of the one I have had I known I could get a TIG and a mig.I've been looking into a home tig setup
https://www.walmart.com/ip/MTS-165-...sUp-Ent-Electronics_pr_dps_dsn_soc_fb_ent_ele
This multi unit looks nice for the money
Did you have a diode in parallel with the solenoid coil to dampen the inductive pulse?I decided to piddle around outside and did an output test on the pwm circuit for the wmeth solenoid. Keep coming up with a low voltage only 3.8v at 100% duty cycle, I know I'm testing with a multimeter but even a noid light wont fire on this circuit. I am no electronics expert but I think the IRLZ44N transistor went bad, these can carry alot of current but a nitrous solenoid being pulsed is alot.
Yes a 1n4001Did you have a diode in parallel with the solenoid coil to dampen the inductive pulse?
