88 mustang GT conv
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 38-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
Fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on the return line coming from the regulator. Stick a bolt in the other end of the hose and make sure that all your connections are tight and leak proof as possible. When this powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge. Turn the ignition switch on and watch for leaks. You may want to use a helper inside the car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachments\68357
Caution!!! You have blocked the return line for the fuel pump! Pressure will rise very quickly past safe levels with a good pump
If the pressure goes up past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does not hit 55 PSI or more in a few seconds, the pump is bad or you have electrical problems.
attachments\68357
Great I will work on this tomorrow! pulled vac, hose off reg no gas present note also spraying carb cleaner into intake will start eng. till it starts to idle then idles just cant give it gas load without it backfiring through plenum
OK checked codes today with no work on car yet except banged on TAD, changed to 41 R , 91 R back to sensors. Actually fuel gauge shows 0 psi but still have to buy hose to plug req. My question is do any of the codes I get have to do with my problem of spray cleaner to start eng. then burps through intake when load in applied. the codes are HO2S lean is it lean because fuel flow is bad or visa versa?
changed valve... OEM test kit from autozone 2 borrowed had cut o-ring in FORD adapter when I got them... Got a third kit from another autozone brand new hand tightened adapter leaked.. 1/4 turn with wrench leaked 1/.2 turn with wrench leaked tightened more and it just got loose again took it off o-ring cut .. a customer in the store said he had the same problem.. anybody else had this problem with OEM test adapter for FORD from autozone?
You can disconnect the fuel line, clamp a hose to the end coming from the tank, put the other end in a can, bucket or your significant other's car, truck or motorcycle and jump the pump at the test port.
