The are the same except for one detail.
Where they bolt to the body is a tube in which the x member can slide back and forth on. They are located in different front/back configurations between aod and 5-spd, and then tack welded in place by the factory.
You can grind the tacks and slide the unit forward or back to suit. Most reproductions are sold unwelded and will fit either
