My fingerMike what did you use to balance out your ITB??
I got a short little video of FIFI taxiing and taking off a couple years ago when I just happened to be at Meacham Airport in Fort Worth where it's based getting my A&P. Impressive machine.
No, I'm serious...I adjusted throttle opening on the middle tb , and then progressively worked from the center outward pressing on the throttle blade ( with my FINGER) and adjusting the respective idle screw until all " lash" was removed from the other tb'sMy finger
The reason he asks is that he is considering buying an ITB system.Well, since, he has done away with the ITBs, isn't balancing them a moot point? I know that ITBs, and dual throat webers are cool and all that, but are they really worth all the trouble on all but all out racing machines?
ludwig said:"https://www.fordsix.com/viewtopic.php?f=2&t=70526&p=543500&hilit=Maserati#p543500"
So I was watching Car W@nkers or whatever that show is where they buy some car cheap and then a stubby English guy with dark hair yells at you while EDD tweaks the poppets.
They had a '76 Maserati (I think) and they called in a tuning specialist. He used a flow meter on each of all EIGHT 1bbl carbs, one at a time. He had to turn the idle down to the same or similar level on each carb and balance the inflow rate x 8. Then they needed TWO guys to set the timing: one under to read the balancer mark and one on top to back off the rotor . Once he got the flow, idle and timing in place, oddly enough, the thing ran better and used less fuel.
BTW, he backed the timing off from about 30* to 14*. Someone had been bumping it up as his performance degraded due to carbs out of adjustment. I can see where EFI and electronic ignition would make a huge difference in EIGHT carbies.
If you take ibuprofen or more that a single baby aspirin, be sure to take omeprazole to control the acid and reduce problems from too much stomach acid. It is over the counter or prescription (cheaper if you have prescription coverage) and it works good. I have been taking it every night for the last 30 years or so with no problems.sorry for your loss.
My gastro doc said ibuprofen is what keeps him in business.
I was given some crazy cough meds once that gave me weird out of body side effects. I won't take any of that crap anymore, i agree i don't understand how people drink that stuff for the high.
.That's because for you the damage is already done. It's not about what you have or haven't taken recently, it's about what you've taken back in the day, when your hair was long, and your thoughts were short(er).I have no idea what's going on and I don't take anything!![]()
