- Mar 2, 2015
- 6,949
- 5,825
- 213
I'm thinking about running metal fuel lines in my 88 fox. The feed line will be 3/8 and the return 5/16. Has anyone done this or helped someone do it. I'll be using a fuel pump assembly with the AN fittings and larger lines. 340lph pump.
The question is...what does everyone use ? Where'd you order it from ?
Y'all should know my set up...but for those that don't I'll tell ya. It's a 331 with TF heads, 42lb injectors ( soon to be 47s ), ported systemax 2, on 3 76mm turbo.
I'm using stock lines now but with tear down season coming I want to build the fuel system a bit. Don't like the idea of braided hoses running the length of the car and prefer the stockish look of hard lines. Have an idea what fittings and such I'd need but would like to get input from the guys here that have done it....or thought about it.
