Before you add any supercharger or turbo setup you should upgrade the oil pump gears and the lower crank sprocket to billet pieces. Having said that, an impeller type supercharger (basically a belt driven turbo) like a vortec or procharger is a lot easier and quicker to install. Any forced induction setup will increase the torque to the point you will have a hard time getting traction on a PP1 car with 3.73 gears. You might be better off with a impeller type setup for the softer hit on the low end, it will make the car much mo
pornjk porn800 redtube re drive able and more enjoyable.
