I work with guys all the time that take a junkyard 351, add cheap heads, a turbo kit..... I regularly max the 67mm turbos on the on3 kits at around 25psi... on a stock hyper piston bottom end in a 351. This will max a set of 60lb dekas easily before the turbo stops making steam so 80lbs are the go to on a budget.
FWIW these guys all end up in the 8.6-9.2s range in the 1/4 mile depending on skill level and vehicle setup. some have gone faster but that is not common and they have more CID and better parts.
I can get a 351w block for next to nothing, the rotating assemblies cost similarly between the two. mass is less a thing with good parts and no reason to not run IB on any build these days for the money involved. its RPM that kills the 2 main blocks due to the rotational mass the IB helps that immensely.
Heads will cost similar between the two of them, regardless i would never build a 357w as I can get more TQ for the SAME money with a larger CID.
FWIW I put my 351w in my fox for less than the cost of the dart block, I would have had to buy the heads, cam, intake anyway so there cost is negated. I did have to buy a UPR k member to make it easy, but all in all the only cost difference was the one AC bracket i had to buy.
Lets step back into the realm of reality, it makes no sense to stroke a 302 when you can do a stroked 351 for the same money.
