Well if I want to do it right the first time, why not talk about a dart block? The consensus is if I did a 347 short block with decent heads, cam and intake you can easily hit 400 hp. So if I do decide to grow from there such as boost, the block is the limiting factor. I understand a dart block might be overkill for my current goals.
Anyways, I see the advantage of going 351 based. I'm wondering what kind of power I can expect from a 408w with TFS 11R 190 heads, mild cam, most likely TFS intake?
Most of you say go 408 but can a 408 be built "mild". Once again, I don't want 500+ hp right now.
You make absolutely zero sense.
Here,....I’ll write slowly.
You don’t have to make some heathen 351 based build Just because it’s a 351. A .030 over 351 with the right heads, intake, and cam will trip all over itself to not make your modest HP goals. Why the 408 number keeps entering the conversation every time you consider the bigger engine baffles me.
And for the record,..the “majority” have recommended a 393.
if you want
simple horsepower, there is no substitute for cubic inches ( I should coin that phrase,...it has a certain ring to it.
Furthermore, having big power is all relative...There’s a long pedal on the floor that controls that. You don’t have to smash it to the floor, just because it‘ll go there.
Consider the big picture. Out one side of your mouth, you are saying that you “ Don’t want more than 400 hp”. while out the other, you’re talking about Dart blocks and stokers. The one cancels out the reason for the other.
IF ( I capitalized that to intimate that you may decide to change your mind)
If, you decide that you wanna step it up, then you also have to decide how big of a shoe you wanna try on.. Cuz the shoes gotta fit If you’re gonna wear it.
If you have a 400 hp combo, and for whatever reason, you decide thats not enough, a 351 based block will safely take you to the 700 hp range. If you choose a stock block 5.0 to make your 400, this is where the need for the Dart block enters the fray.
Again,....let’s review.
COMPLETE 351 JY engines are what???.....300-500?
BARE Dart blocks are...2 GRAND?
How hard is this?
Lets all go outside now, and do something
harder than choosing an engine to make 400 hp, with potential for almost twice that for a fraction of what a stroked Dart block combo will cost....like, fall off a log.
