Coolant etching on cylinder walls
Cannon77550
42
32
28
Galveston, TX
Hey guys, I have an issue and was looking for everyones opinion. So I have been doing head gaskets on my 95 5.0 for a few months, working on it here and there when I have time. Well when I pulled it apart I water in cylinder #4 & #8. I soaked up what I could and went about cleaning everything up. Well yesterday I took on doing final cleanup under the hood before I start reassembling and discovered both cylinders have some etching on the cylinder walls where coolant was sitting on top of the rings. It isnt terribly bad but it definitely isnt good. My problem is I cant afford to rebuild the bottom end right now. Question is, do I let it sit until I can afford to do it. Or do i put it back together and see what happens and do the bottem end at a later date. Right now with all this virus bull:poo: I'm out of work, and it is ussually my daily when im working. Let me know what ya think. Thanks guys
This is #4. I think its shot looking at the pic. What do you guys think?
Can you feel the etching with your fingernail? I've polished out crap like that before with sandpaper. I'll probably get crucified for that statement but it worked. Looks like you never sprayed any lubricant on it after you cleaned up the coolant. If it were me,I'd clean it up,buy the cheap Felpro gasket kit and put it back together.
I can barely feel it with my finger nail. I think for now I'll just try to use some fine sand paper and knock it down a little and put her back together. I understand it probably wont last forever, and I'll prolly get some blow by but it shouldn't be the end of the world. It's a stock motor anyways, so it's always been slow lol. Eventually I'd like to build a motor for it anyways.
Throw some Marvel Mystery Oil in there and turn it over by hand a few times. That looks like light surface rust, and if you can't feel it with your finger nail, I wouldn't waste your time on it. What's the worst that can happen, you have to do a bottom end rebuild for low compression later instead of doing a bottom end rebuild now? I'd send it.
Kurt
Reactions: General karthief
To be honest, I wouldn't touch it. Wipe the wall down with oil and turn the engine over by hand. If you can't catch it with your finger leave it alone. One teeny tiny low spot is one thing....if you sand the wall you could make a big dent that would be worse.
I wouldn't sand it unless the piston was pulled. The sanding would put a bunch of debris in the cylinder that is nearly impossible to get all out with the piston still in there.
Kurt
Probably should've been more clear. I'm not advocating going in there and dry sanding the wall. I get the piston at the bottom of the hole and stuff a rag in there. Then 6-800 grit paper and shoot the wall with some wd40. Lightly, LIGHTLY sand the wall,it doesn't take much really. Done this a bunch of times on JY engines,never had an issue. But hey, OP do whatever you think is best.
Appreciate your opinion guys. Tomorrow I'm gonna go down and clean it up real good and oil up the cylinders and turn it over by hand. If I think it needs any smoothing out I'll lightly hit it with some 600 grit. Just around the edges to take any "ridging" I may feel out a little. But honestly I think I'm gonna try to stay away from doing that. Shes prolly just gonna get cleaned up and get some oil. I know one thing.... it might not run worth a :poo: but itll look good under the hood when I'm done lol. I have cleaned and repainted everything as I went along.
