I’d like to covert the front of my car to use the center cap to my 5 lug wheels. I have svo rotors with the stock foxbody capilers. I’d like to keep those so my question is can I use a sn95spindle with my capliers so can I do that?
You can use your old calipers to get the core charge back if you buy new calipers for a 99-04 GT... Thats what I did. Ended up costing like $100 total with new brake lines and the adapter fitting.
They came with the brackets. I did have to grind a little bit off the spindle though to fit the 99-04 calipers. Nothing major at all. Took like 5min per side. It’s obvious what needs to be grinded when you go to put the caliper on the bracket.
Or the 94-98 calipers fit with no grinding, but the 99-04 ones are the twin piston style. They are debatably better.
I think he used sn95 spindles and calipers, but used his old calipers to return as the core when he bought the sn95 stuff. But I could be reading it wrong.That's pretty sweet. I had to source my brackets elsewhere. Do you happen to have the ordering and part info for the set you got with brackets?
That is exactly correct. Sorry if I made it confusingI think he used sn95 spindles and calipers, but used his old calipers to return as the core when he bought the sn95 stuff. But I could be reading it wrong.
