Anybody ever hear of Thunder intake for 5.0?
If you look behind where the dist would be on a Mustang, there's a part number cast into the lower intake.
F87E-9K461-BA is the early EGR style manifold. The 65mm TB can also be modified to work on a FOx
F87E-9K461-BB is the later style non-EGR intake manifold.
If you have the choice, the -BA intake is the one to get. Take the TB and the injectors as well
Got it. Thanks for the additional advice.
There you go. There is also some company out there that makes a factory looking "5.0 HO" intake plate to fit on an Explorer intake.
Kurt
That company would be Ford ;)
The stock HO plate fits on fine.
Reactions: Shakerhood
The only real difference on the intake plate is that two of the holes in the Explorer upper are left undrilled. You have to drill and tap those holes if you want to use all four mounting screws.
Very cool. I actually got curious and ended up finding your intake in google search.
Kurt
That one wasn’t mine. Just a random intake off the net.
here’s mine, but I’m actually going to run a 93 cobra intake. This one will be a wall-hanger
I put a little extra work into it to make it look like a stock HO intake. Ground the nub off the side and took off some casting flash to smooth it up a bit like the HO upper.
That’s exactly what I want to do with the intake I have. Going to go on my Mercury eventually.
Hit paydirt at boneyard in Hazleton PA this morning. Got the intake and throttle body for $85. Injectors were caked with sludge so I passed on those. Thx for all the tips and advice I got on this.
Reactions: 90sickfox
