I have a 79 coupe im doing a coyote swap on. Im looking at purchasing a 96gt for the hydroboost system. My question is what else can I use from the 96gt? Power steering rack? rear end?
I was going with a max motorsports k member so perfect. Thank you!Yes, you can use everything you’ve listed. If you purchase a k member that relocates the steering rack (like max motorsports) you can use the spindkes as well.
"Hydroboost from the new edge" years and models please? I'm trying to figure out a parts list. Spindles, hydroboost front and rear calipers. Power steering rack and a rear end. Any thoughts on which years and models I should be looking for to find parts listed above?I'd have a full plan in place before buying an entire car. The hydroboost from the new edge is a little more desirable and easier to obtain should the donor cars one leak, the front calipers on a gt aren't the most attractive and the spindles stick out further (94/95 is most sought after) . The rear is wider eliminating quite a few wheel choices.
You may find that buying and stripping down a 96 may be more money and effort than it's worth.
New edge is 99-04. It’s the more preferred hydroboost unit for feel and parts availability. The spindkes are the same, front brakes are a little bit better, but the rear axle housing is my really desirable. You want an 86-98 8.8 axle housing. You can swap the rear brakes from the new edge over but you’ll need new axle shafts and offset caliper brackets
I’m in the middle of putting a 99-04 hydroboost on my car
The rack won't change anything, it's the supply that's the problem, since all the Coyote cars are electric power steering. There are two options. You can get the power steering pump kit from Power by The Hour, or you can put an electric power steering pump out of a Volvo CX90 in it. Check out the facebook group "Coyote Swapped Foxbodies" for more options.Any thoughts on power steering? Should I get a rack from the new edge also?
Ford Mustang Cobra 11.65" Rear Disc Brake Conversion 79 93 87 Fox body SVT 5.0 | eBay Cobra 11.65" Rear Brake Conversion for '79-'93 Fox Mustangs & Clones. Our competitors can only benchmark off of us to try and catch up. Designed off of Ford's own prints & CAD models and analyzed through COSMOS FEA software to confirm our own strain gauge data to produce the best design and highest factor of safety on the market. www.ebay.com |
Brake Rotors [FULL KIT] POWERSPORT DRILL/SLOT -Ford MUSTANG 1994 - 2004 Cobra | eBay Front & Rear POWERSPORT Cross-Drilled & Slotted Brake Rotors. Ford MUSTANG [1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004] Cobra, Bullit, Mach, SVT Cobra & 10th Anniversary Edition. www.ebay.com |
BrakeBest Brake Caliper - Remanufactured 18B4655 | O'Reilly Auto Parts Shop for BrakeBest Brake Caliper - Remanufactured Part #: 18B4655 for your 1994 Ford Mustang. Get product details, choose a store, and get directions. Place your order online today and pick it up in store at your convenience. Visit our site for coupons and promotions. Bracketed Brake Caliper With Installation Hardware www.oreillyauto.com |
BrakeBest Brake Caliper - Remanufactured 18B4545 | O'Reilly Auto Parts Shop for BrakeBest Brake Caliper - Remanufactured Part #: 18B4545 for your 1995 Ford Mustang. Get product details, choose a store, and get directions. Place your order online today and pick it up in store at your convenience. Visit our site for coupons and promotions. Brake Caliper; BrakeBest Remanufactured Brake Cali www.oreillyauto.com |
BrakeBest Select Semi-Metallic Front Disc Brake Pads SM412 | O'Reilly Auto Parts Shop for BrakeBest Select Semi-Metallic Front Disc Brake Pads Part #: SM412 for your 1994 Ford Mustang. Get product details, choose a store, and get directions. Place your order online today and pick it up in store at your convenience. Visit our site for coupons and promotions. Disc Brake Pads www.oreillyauto.com |
Motorcraft Rear Disc Brake Pads NBR627 | O'Reilly Auto Parts Shop for Motorcraft Rear Disc Brake Pads Part #: NBR627 for your 1995 Ford Mustang. Get product details, choose a store, and get directions. Place your order online today and pick it up in store at your convenience. Visit our site for coupons and promotions. Disc Brake Pads; The only parts recommended by Ford Motor Co www.oreillyauto.com |
That could be a sticky?The rack won't change anything, it's the supply that's the problem, since all the Coyote cars are electric power steering. There are two options. You can get the power steering pump kit from Power by The Hour, or you can put an electric power steering pump out of a Volvo CX90 in it. Check out the facebook group "Coyote Swapped Foxbodies" for more options.
As for the brakes, I just priced out how to convert a foxbody car to Cobra brakes for around $600. SN Cobra brakes are more than the car will ever need on street tires. Bon Appetite.
rear bracket.
http://rover.ebay.com/rover/1/711-5...0001&campid=5335821607&icep_item=321889900512
www.ebay.com
$104.95
http://rover.ebay.com/rover/1/711-5...0001&campid=5335821607&icep_item=274491501675
www.ebay.com
$167.52
Front Calipers
https://www.oreillyauto.com/detail/...34933/1994/ford/mustang?q=brake+caliper&pos=0
www.oreillyauto.com
$59.99 (x2 for each side)
Rear caliper
https://www.oreillyauto.com/detail/...2514/1995/ford/mustang?q=brake+caliper&pos=15
$60.99 (x2 for both calipers)
www.oreillyauto.com
Brake Pad front
https://www.oreillyauto.com/detail/...2/4548926/1994/ford/mustang?q=brake+pad&pos=1
$39.99
www.oreillyauto.com
Rear Brake Pads
https://www.oreillyauto.com/detail/.../5996819/1995/ford/mustang?q=brake+pad&pos=11
$31.99
www.oreillyauto.com
Add some bolts and some brake lines.
Total $586.41
Kurt
If you want it to be a sticky I'll add context to it. There's some tricks in there you have to know, like those rear calipers that come with the brackets from O'Reilly's are actually for a Mustang GT, and aren't identical to the Cobra ones, but function the same. The Ford Cobra upgrade kit for a GT actually re uses the factory GT calipers. You also have to know that there are core charges on all this stuff. So don't be an idiot and bring old calipers with you. Buy the calipers first, pay the core charge, and then return the boxes with any junk yard caliper in them. The parts guy doesn't know the difference between a Cobra caliper and one off a Dodge Colt. Moreover, as soon as he slaps a core return sticker on the box, it's someone else's problem, and there is no reason to argue with a customer over it.That could be a sticky?
