Engine Compression very low, options
Trebor
PA
Hello all. I had picked up a 92 GT Vert in really good condition. GT 40 tubular intake, vortech V1, 24lb injectors, MFU. Ran ok but sluggish, I knew something was wrong. Brought it in for a compression check. I am being told that all the cylinders are in the 80 psi range with oil. Recommending replacing engine with a crate motor. I plan on keeping the car for a long time, but I don't want to drop a ton of money on the engine. I'd honestly be happy with the stock engine, the vortech, 42 injectors and fuel pump to elminate the FMU, and a terminator x. Considering the cost of labor in NJ, what kinda of options do I have?
For less than 5k shipped my friend got a stroker 347 longblock crate engine from blueprint engines. It has a 3 year warranty, aluminum heads and made over 430 HP. The second option is to take your existing engine out and have it rebuilt. I had an engine built recently for my turbo car. The short block rebuild was around 2k.
You have tons of options depending on what you want to do with the car. The engine may have just jumped time. the older ones had a phenolic cam gear. Jersey great love visiting the pike. Find someone like me at your local autozone who is willing to come over and tear down the motor a little. Check the valve springs and the cam timing. It takes the big 3 to start and you are missing 1. This is just your first engine. Owned my stang for 43 years and had 3 or four motors and trans in it for fun. Back to a owning a stock boss motor but currently running a Gapp and Roush prepped bogus boss with modified 4v351 heads. All Fun Stuff
I spent a ton of money on mine back in the day. I am a tech and I know machinists so it is easy for me. I also make a ton of money and that helps. These days I do mechanic work on old classics for fun or for free. You need a balance shaft in your benz thats 10k. Go to az and see who is going behind the counter to buy parts. That will be a commercial guy like me. Ask the counter man if they trust anybody. Find an honest one who will not break your balls. Let me know how it turns out
Thanks for the information. I just don’t like where this seemed to be headed. I got the talk about how once the engine is make the hp it’s going to show problems with the transmission etc.
If I bought a just new block and aluminum heads how much of my current parts can be reused ?
What trans do you have? You should be able to transfer all the internals too if you bought a new block SVO for instance. Is your block toast? Is your crank okay? Are the rods round and straight? A crate motor just means it comes with manifolds waterpump and timing belt if equipped and ignition parts. Oil pan and valve covers. All pretty but added expense. Some come with no core charge so you can keep your motor and see what went wrong, Like a spun lifter or a round cam shrunk piston etc. Most of the Transmissions these days are only good for 300 to 400 ft lbs of torque. I think my early ZF 6 speed is good for 350 and it is noisy. The later ones are good for 320 and are quieter. Most T5's are only good for 300 or so. RUG toploader 4 speeds are tough around 400 maybe. Do not worry about the trans they are cheap. Scattered a few myself fun stuff
80psi on all cylinders? That’s kinda odd really. I’d be seeking a second opinion on that report.
There are things that can make cylinders go down to 80psi, but equally across all cylinders is odd. Was it controlling oil ok or was it smoking out the exhaust? What about coolant? Was it holding coolant ok?
Reactions: Monkeybutt2000
One thing that can cause low compression across all cylinders is severely retarded cam timing. If that’s the problem, it can be fixed without replacing the engine.
Cams with really long duration will also lower cranking compression across the board.
Combine long duration and retarded cam timing and you’re making it even worse.
I would hesitate buying a new engine until you’re sure what the problem is.
Reactions: Gs1987GT
80 psi sounds like the cam is not spinning or jumped a tooth
I would not buy squat until a teardown and inspect
You can have the dealer TDI it for you for around 400 in 1990 dollars
The motor man at the dealer will want to pull both heads and both the intakes at least
Talk them out of inspecting the crank and rods. You should assume that at least some of the momo is ok
Went to the shop yesterday. Hooked up a gauge to a few different cylinders. Plugs were all out. Intake was as shown in pic. Turned the engine over. First reading was 100 psi. Cleared gauge turned over again. 80 psi.
My plan right now is to change the valve cover gaskets, because they were leaking bad, change the plugs, put it back together. Enjoy what it is till I find an affordable option or a friend that will do the work with me.
